Indications You Septic Tank Needs To Be Pumped? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree33Likes
Old 02-09-2020, 06:12 PM
Mike Milam's Avatar
Rewards Points: 128
Indications you septic tank needs to be pumped?
I've lived in my home for 11 years and it was built in 2002. I have put Rid-x in as I should. What signs/symptoms should I notice when it needs to be emptied?
Thank a police officer for being the one who runs 'TO' a report of shots fired, while everyone else runs 'AWAY'
Mike Milam is offline
Old 02-09-2020, 06:27 PM
Rewards Points: 2,690
Re: Indications you septic tank needs to be pumped?
I would say the usual signs like sewer backing up, drains taking longer/slower than usual to drain, pooling of water in yard depending how it's plumbed, etc.
Just as a general guideline it's best to have your septic pumped out about every 5 years or so even if there are no signs. Just a suggestion and my opinion only.
Bondo, de-nagorg and Mike Milam like this.
jmon is online now
The Following User Says Thank You to jmon For This Useful Post:
Mike Milam (02-09-2020)
Naildriver
chandler48's Avatar
Rewards Points: 1,334
Our house was built in the 70's, and we've lived there 20 years without a pump. Granted we are due for the obligatory 5 year pump many times over. It's just the two of us, and we watch water usage, and use enzymes, too.
Sure indications will emerge by back up in a lower level shower usually. But it's too late, by then. I'd go to the county health department and obtain a plat of the septic permit showing the measurements to the tank from the house corners. You can save $100+ if you locate the tank and have the doors exposed for the pump company.
de-nagorg, Yodaman and Mike Milam like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline
The Following User Says Thank You to chandler48 For This Useful Post:
Old 02-09-2020, 06:43 PM
Super Moderator
joed's Avatar
Rewards Points: 30,548
I would say by the time you see signs it needs pumping it is too late. The sludge will have infiltrated and ruined the tile bed.
After 11 years I would have it pumped. The pump person will tell you how bad it was and if it could have gone longer. Use that to judge when to pump next.
joed is online now
Old 02-09-2020, 07:55 PM
Rewards Points: 628
A properly operating septic system isn't going to give you any signs that it needs pumping. If it does, then the damage is probably already done. Having your tank pumped is preventive maintenance to keeping the system operating properly and last as long as possible. Around here, it costs $175 to get it pumped out. Last year, I had the company put in a riser and a cap so they wouldn't have to dig out the tank lid every time. Now they just have to remove the cover, lift the concrete tank lid and pump it out. I think the riser cost $100. I have it pumped out every year but only because I rent the home out a few weeks in summer and I don't want to worry that the renters flushed something they shouldn't have. So it's cheap insurance.
taylorjm is offline
The Following User Says Thank You to taylorjm For This Useful Post:
Old 02-09-2020, 09:49 PM
Usually Confused
lenaitch's Avatar
Rewards Points: 976
Agree that if you wait for signs that the system is no longer working (back-up, ponding, etc.) , it's too late.
We had a back-up once at a previous house. Luckily, it was because of a blockage at an elbow in the feed line from the house and not a problem with the system itself. Also luckily, it was primarily discharge from the dishwasher and not after a night of burrito-fest.
We have ours pumped every 5-6 years - it's cheap insurance and not that expensive (I dig out the lids). Our municipality requires a pump/inspection every 7 years with a copy of the report filed with them, so I'm always ahead of their schedule.
_________________________________________
Sic Itur ad Astra
lenaitch is offline
The Following User Says Thank You to lenaitch For This Useful Post:
Old 02-09-2020, 11:06 PM
Mystriss's Avatar
Rewards Points: 4,896
We pump ours out every summer...
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline
Old 02-09-2020, 11:20 PM
JUSTA MEMBER
Rewards Points: 1,592
Here it is mandatory to have a pump out riser and cap installed at the time of tank installation.
And you should have a double clean-out in the line from the house to the tank, that way rooter service can access the line in case of a blockage.
Putting the enzymes in helps to break down the paper and solids, and if the leach field is working proper, there should not be any problems.
Having it pumped every 5-8 years is a very good idea, as a prevention tool.
ED
de-nagorg is online now
The Following User Says Thank You to de-nagorg For This Useful Post:
Mike Milam (02-10-2020)
Old 02-09-2020, 11:51 PM
Rewards Points: 3,558
We pump every 3 years. And I clean the strainer once per year minimum.
We have tank risers with above grade lids that makes it very easy to access.
roughneck is online now
The Following User Says Thank You to roughneck For This Useful Post:
Old 02-10-2020, 12:18 AM
Rewards Points: 1,044
The bacteria in a regularly used septic tank is sufficient without adding anything. Generally the only time additives are needed is in seasonally used systems that don’t get a fresh supply of s—-.
de-nagorg likes this.
Old Thomas is offline
The Following User Says Thank You to Old Thomas For This Useful Post:
Old 02-10-2020, 06:02 AM
Naildriver
chandler48's Avatar
This is what saves you money on pumping.....not having to locate it and not having to dig down to the lids. I think both cost less than $150. I put these on our former rental cabin.
Larry......
Old 02-10-2020, 06:30 AM
retired painter
Rewards Points: 1,816
I live on top of a steep hill and it's difficult to get a pump truck to my house. While a truck can come up my road - most truck drivers are scared and won't try. It took me 7-8 yrs of trying [on/off] to get a pumper up there. If I remember correctly I was charged $325, I already had the lid exposed. That was the first time the tank was pumped after 25 yrs of service. It wasn't as bad as I expected. BUT our kitchen sink and washing machine don't use the septic system and I empty a packet of yeast into the system every month or two.
mark sr is online now
The Following User Says Thank You to mark sr For This Useful Post:
Old 02-12-2020, 11:09 AM
Rewards Points: 34
Around here for maintenance pumping, the going time between pumps told to everyone by the experts (assuming a sand mound system) was two years, but I had a new system built 18 months ago and the official pump recommendation on the septic permit was every three years. I know some who have gone 19+ years without pumping and no issues.
chuckzwood is offline
Old 02-12-2020, 11:18 AM
Rewards Points: 44
Everything I've ever read says don't bother with Yeast and/or Rid-x. If the system is functioning properly, no additives are needed.
I agree with many of the other posters. 1. Once you know you need to pump, its too late, and 2. Do it every 3 to 5 years depending on use as preventative maintenance.
Where I live the local government is mandating a pump every 3 years or they can fine you.
edfiero1 is offline
Old 02-12-2020, 11:19 AM
ZTMAN's Avatar
Rewards Points: 492
Local ordinance requires us to pump the tank at our house every four years.
Owned our hunting camp for 22 years, don't even know where the tank is, never tried to find it, but it is used sparingly.
If I need to locate a tank, or one of the inspection pipes, I use a pitch fork when the ground is soft.
I don't mind spending money, I mind wasting money.
ZTMAN is offline
