Increased Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-05-2015, 09:48 PM   #16
Rewards Points: 3,430
You're welcome. Let us know how everything worked out for you. Thanks.
jmon is offline   Reply With Quote
Old 04-11-2015, 10:30 AM   #17
Rewards Points: 24
Hello everyone, finally got to installing all the parts I received in. All went well and thank God no leaks. I even went ahead and installed a new anode rod, this would be the third rod installed on this tank including factory one.
I set the pressure regulator to 65 PSI and upon heating the pressure only went up several PSI above that was nothing substantial as before it would rise above 100 PSI. Everything seems to function well and hopefully this resolves the issue I been struggling with.
I am glad I installed a new rod as the old one was in bad shape from attack. see the pics.
Thanks Ben and everyone for their input and suggestions.
https://41.media.tumblr.com/7618d544...m6co1_1280.jpg
https://40.media.tumblr.com/472171f9...8m6co2_540.jpg
https://40.media.tumblr.com/14c458bd...8m6co3_540.jpg
mike123333 is offline   Reply With Quote
The Following User Says Thank You to mike123333 For This Useful Post:
jmon (04-11-2015)
Old 04-11-2015, 11:06 AM   #18
Nice job! Thanks for the update and pics.
The pictures of your ate up anode rod shows the importance of changing them out every few years to extend the life of the tank. Nice thinking.
Old 04-11-2015, 05:59 PM   #19
Rewards Points: 582
excellent job ..
Weird water pressure issue in house... tenants moving in today, any ideas? (w/pics) tireshark Plumbing 9 08-19-2014 03:54 PM
Low water pressure (hot water only) - temp fix when I shut off water supply to tank skilletrx Plumbing 5 11-15-2012 07:37 AM
Well Water Pressure Fluctuation cforbes Plumbing 13 10-01-2012 06:52 AM
Check valve gimaarob Plumbing 13 10-27-2011 10:13 PM
