Inadequate Hot Water After Installing New Water Lines - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree7Likes
Old 12-17-2017, 10:02 PM   #1
Rewards Points: 28
Inadequate hot water after installing new water lines
After tapping into the main water lines to run new lines to a new bathroom in the basement, we run out of hot water much quicker than usual. Also, the water will fluctuate between warm to hot, then back to warm until we run out of hot water completely. It seems the water heater isn't able to fully heat all the water. This is a 4-month-old gas water heater. Power vent.
I know there is/was some air left in the new water lines since I only roughed in the plumbing for the new bathroom and capped off the nipples for the fixtures. We could hear some air coming out of the faucets in other rooms in the house, but now that isn't happening anymore. I'm thinking there's still air trapped somewhere in the water lines and that's what is causing our issue with the water heater.
Thoughts?
ttsellen is offline   Reply With Quote
Old 12-17-2017, 10:11 PM   #2
hkstroud's Avatar
Rewards Points: 6,694
Re: Inadequate hot water after installing new water lines
Nope, that's not it.
Do you by any chance have a hot water recirculation system?
What kind of pipe?
MTN REMODEL LLC likes this.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 12-18-2017, 03:00 AM   #3
Rewards Points: 28
No recirculation system. We have Pex
Old 12-18-2017, 05:15 AM   #4
Naildriver
chandler48's Avatar
Rewards Points: 3,596
How long are your runs from the water heater to the furthest point and what size PEX did you use for the main runs?
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 12-18-2017, 05:21 AM   #5
hkstroud's Avatar
Does your water heater have heat trap nipples?
Harold,
Old 12-18-2017, 07:28 AM   #6
Peace be with you
DR P's Avatar
Rewards Points: 1,860
install the guts/controls into the tub/shower valve or isolate that rough in piping and problem most likely goes back away
Peace
DR P is offline   Reply With Quote
Old 12-18-2017, 07:29 AM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 258
If you installed a new tub/shower valve, be sure it has a cartridge inside it.
Old 12-18-2017, 07:32 AM   #8
Rewards Points: 28
No heat trap nipples. The main runs are 3/4". The furthest point in the system is about the same as is was before I tapped into the main lines. There is an existing bathroom that has lines going further than the new bathroom lines that I ran.
I really didn't change much except trapping air into the system, but it seems that's not the culprit from what you guys are saying.
This all started immediately after I ran the new lines off of the main.
Old 12-18-2017, 07:35 AM   #9
Rewards Points: 28
I did in fact install a new Delta shower/tub valve. Don't they come with the cartridge inside already? It was the rough in kit that I installed.
Old 12-18-2017, 07:45 AM   #10
Rewards Points: 28
Here's what I installed. Delta Faucet R10000-UNBX MultiChoice Universal Tub and Shower Valve Body
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Thank you for all the help so far guys.
Old 12-18-2017, 07:53 AM   #11
Plumber
Rewards Points: 258
Delta's cartridge comes with the trim kit.
Old 12-18-2017, 08:11 AM   #12
Rewards Points: 28
Okay. Thank you! I'll order the cartridge and see if that takes care of it.
Old 12-18-2017, 09:27 AM   #13
ZTMAN's Avatar
Rewards Points: 628
If you look at the description of what you bought, it does not come with a cartridge. I think you have identified your problem
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 12-18-2017, 09:44 AM   #14
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,870
As HK-E figured above, just back/reverse circulating hot/cold water at your shower valve with no cartridge.
akuhn235 likes this.
MTN REMODEL LLC is online now   Reply With Quote
Old 12-20-2017, 06:12 PM   #15
Rewards Points: 126
sounds like a cross flow problem as stated above! Don't new water heaters typically come with check valves to avoid this problem?
akuhn235 is offline   Reply With Quote
Installing a Water Softener amorak Plumbing 3 05-04-2012 10:56 PM
Air in hot water lines (well system) John_H Plumbing 3 04-29-2012 10:05 PM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 12:23 PM
