I'm Confused On This - - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-30-2015, 10:03 AM   #1
Rewards Points: 1,238
I'm confused on this -
I've already got some great feedback from others on my shower remodel project, but I'm confused on this aspect of it.
I'm about to fill this area in with concrete and wil be using this drain. With that said, how deep to I bevel the concrete around the pipe?
Should I just fill in the area with concrete and chip away as necessary after it hardens or make the bevel while it's wet.
Now that I think of it, maybe this isn't the right drain??! I'm installing a Kohler shower base made from Vicrell (plastic). I assume I need a compression strainer/drain? Is this correct?
http://www.homedepot.com/p/Oatey-2-i...2210/100342534
Daugela is offline   Reply With Quote
Old 12-30-2015, 11:05 AM   #2
I just re-read the description of the drain and it says it's for tile and marble only. So that's not the right one...
This one:
http://www.homedepot.com/p/Sioux-Chi...7-2B/202313081
Old 12-30-2015, 11:28 AM   #3
Rewards Points: 767
Normally we put a 5 gallon bucket over the riser and pour around it. I just helped my brother in law set a pan over the weekend that had a 11" x 11" inset around the drain so we had to accommodate for that. Check your pan to make sure
ct18 is offline   Reply With Quote
Old 12-30-2015, 12:01 PM   #4
Yeah, maybe it's best to just to wait for my pan to come in and do a dry fit before I do this pour.
Old 12-30-2015, 03:16 PM   #5
Rewards Points: 1,862
Fill the hole to the left part, leave 6 inch space where it comes up. Stick a large plastic bowel with a hole in the middle on the 2 inch inlet.
Old 12-30-2015, 10:42 PM   #6
I'm not quite following you. What 'left' part? 6 inches of space from where? From the level of the existing concrete floor?
Old 12-30-2015, 10:48 PM   #7
From the center of the 2 inch pipe your shower drains into. You have to leave room under the base for the shower drain that you will mount on your base. All your doing is filling in the extra broken concrete area. Just cut a large coffee can ends off and center it on your drain. Pour the concrete and remove the coffee can after it solidifies.
Old 12-30-2015, 10:51 PM   #8
awesome! Thanks Ghost
Confused about fence post concretes d189379 Landscaping & Lawn Care 12 09-27-2014 11:50 AM
Utterly confused - air barriers when finishing attic? s2m Insulation 5 12-11-2012 10:28 PM
Yes another basement insulation question...confused jdtox Insulation 5 10-15-2012 01:48 PM
Confused about Sub Panel stqevo Electrical 28 10-01-2009 11:04 PM
Trying to wire my bathroom... confused... Alan Electrical 3 11-23-2008 04:44 PM
