If ItĚs Not Broken Why Replace It - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-17-2016, 01:24 AM   #1
Rewards Points: 34
If Itís Not Broken Why Replace It
I have a 30-gallon Rheem (Model 813V30D) water heater that is almost 18 years old in a closet below my A/C unit. I live on the second floor of a condominium complex. Itís NOT giving me any trouble. Like they say, ďIf its not broken donít fix it.Ē
I have some questionsÖ
1. Should I replace it now before it gives me a problem?
2. How long will a water heater last?
3. If and when it does brake, whatís the worst that could happen?
Thank you,
Scotty
Scotty13 is offline   Reply With Quote
Old 04-17-2016, 05:41 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Re: If Itís Not Broken Why Replace It
Question, does it it have a safety pan with an outside drain?
The worst is a flood when you are not home that causes thousands of $$ of damage. I have seen WHs last longer than 18 years and I have seen them go in 7-8. A lot depends on water chemistry.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
joecaption (04-17-2016)
Old 04-17-2016, 07:44 AM   #3
Rewards Points: 127
Replace it. The damage from a leak while you aren't home can be extensive. You will be responsible for the damage to your unit and the unit below you as well as an personal property of the condo owner below you. As it is on a second floor I buy the best unit I could afford.
jimn01 is offline   Reply With Quote
The Following User Says Thank You to jimn01 For This Useful Post:
Old 04-17-2016, 07:56 AM   #4
Rewards Points: 18,784
Whole lot cheaper to replace it then having to deal and pay for all the damage a failed heater can do.
I'm surprised it's not code to install an auto shut off on water heaters considering the damage they cause.
http://www.watts.com/pages/whatsnew/floodsafe_wds.asp
Old 04-17-2016, 08:21 AM   #5
Rewards Points: 374
18 years is a great run! I wouldn't push it...especially on the 2nd floor. I was lucky. My water heater developed a slow leak to let me know it was dying. It didn't have a pan with drainage but luckily it was in the basement near the sump so it didn't do any damage.
An ounce of prevention...yada yada yada.
costgeek is offline   Reply With Quote
Old 04-17-2016, 08:31 AM   #6
ZZZZZ's Avatar
Rewards Points: 2,428
Originally Posted by Scotty13 View Post
Like they say, “If it's not broken don’t fix it.”
In the business world, they also say: "if it ain't broke, break it!"
Questions to ask yourself:
Will replacing the water heater open up a whole new can of worms?
Will a plumber have adequate access to change it out? Will he have to do "surgery" to the walls, the floor, whatever...
Are you planning on living in this condo for a long time to come?
What's the general condition of the plumbing?
Is a 30 gallon tank big enough?
Have you considered an energy-efficient (but expensive) tank-less water heater?
ZZZZZ is online now   Reply With Quote
Old 04-17-2016, 09:38 AM   #7
Rewards Points: 3,282
If you don't already have a drain pan, the act of installing one will probably cost enough to make replacing the water heater at the same time worthwhile.
You can greatly reduce the chance of a catastrophic flood by turning off the water heater inlet (better yet, the water feed to your unit) whenever you go out and also have one or more flood alarms to alert you when your are home.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
AllanJ is online now   Reply With Quote
Old 04-17-2016, 12:12 PM   #8
Rewards Points: 198
ZZZZ your last question I have a quarrel with only because Tank less are far too expensive compared to a Tank Water Heater and that they require maintenance every 6 months if you want to extend the life of the tank less heater. These maintenance calls take a couple of hours and probably more than $200 each depending on the area you live in. When you do the research on Tank less, they just don't compare to correctly installing the old fashion tank water heaters from an economical stand point. As for installation, the costs can be huge depending on the Vent system you need to pass inspection. Do your own research, but I will pass on Tankless unless there is no alternative. To answer your question, replace it properly now in order to sleep at night.
srloren is offline   Reply With Quote
Old 04-17-2016, 12:26 PM   #9
Rewards Points: 10,410
Floods the unit below you, and does $20,000 in damage.
SPS-1 is offline   Reply With Quote
Old 04-17-2016, 12:34 PM   #10
Rewards Points: 127
Maybe more if the downstairs guy has a 60 inch tv and a really nice surround sound system or his antique mahogany dining table set gets damaged . 20 grand is probably just the structural and finish materials never mind the contents . Hope your insurance is paid up
Old 04-17-2016, 01:13 PM   #11
Rewards Points: 198
I can speak from experience, my main bath room lavatory overflowed and caused 26 Grand plus damage. Good thing I had homeowners insurance to cover it. I do have $1000 deductible and a really good insurance company purchased through Costco. I replaced my man made laminate with real wood laminate and my home looks great again.
Old 04-17-2016, 01:46 PM   #12
ZZZZZ's Avatar
I just asked that you consider tankless. I did say it was expensive. I agree, it's not for everyone.
The Following User Says Thank You to ZZZZZ For This Useful Post:
TheEplumber (04-17-2016)
Old 04-18-2016, 01:25 AM   #13
Rewards Points: 34
Thank you for ALL your feedback. I’m going to go ahead and replace my water heater.
The Following 2 Users Say Thank You to Scotty13 For This Useful Post:
jmon (04-18-2016), r0ckstarr (04-18-2016)
Old 04-18-2016, 07:34 AM   #14
r0ckstarr's Avatar
Rewards Points: 82
Glad to hear you're replacing it. My water heater was just as old as yours. I put off replacing it with the same line of thinking as you. "I'll replace it when it breaks."
About 4-5 months ago, I was leaving to go to work, and just as I was about to get into my truck, I heard water dripping. Knowing this wasn't a sound I had heard in the garage before, I started looking around. The water heater was leaking from the bottom. If it would have busted 5mins later, I would have come home to a wet garage. I shut it off, drained it, disconnected it and went to work. I replaced it that evening.
The scrap yard gave me almost $5.00 for the old one. When I rolled it over in the bed of my truck, about 5 pounds of rust flakes fell out of the bottom of it. I'm not exaggerating on the amount of rust flakes either.
r0ckstarr is offline   Reply With Quote
The Following User Says Thank You to r0ckstarr For This Useful Post:
oh'mike (04-18-2016)
Must I replace the coil when I replace the outside condenser unit? plichtenstein HVAC 5 08-24-2010 02:41 PM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 01:54 PM
replace galvanized pipe below kitchen sink? Jeremy Hillary Boob, PhD Plumbing 3 04-03-2009 08:39 AM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 09:40 AM
