Identify Water Softner - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-06-2016, 07:16 PM   #1
jackfox1968's Avatar
Rewards Points: 20
Hi - I lost the documentation to my water softner and believe it or not there is no name brand on it! Does anyone recognize the brand/model?
jackfox1968 is offline   Reply With Quote
Old 01-07-2016, 11:42 AM   #2
Water Treatment
Akpsdvan's Avatar
Rewards Points: 1,184
It is an new Erie valve.
Here a link to the valve manual.
http://watersoftenerdr.com/images/Erie_Manual_2401.pdf
Have Fun.
Akpsdvan is offline   Reply With Quote
The Following User Says Thank You to Akpsdvan For This Useful Post:
jackfox1968 (01-07-2016)
Old 01-07-2016, 12:11 PM   #3
Rewards Points: 20
Aquatron AWS-1248 according to the company that installed it 11 years ago.
Old 01-07-2016, 12:14 PM   #4
Rewards Points: 20
However the link you supplied looks just like the head unit I have.
Old 01-07-2016, 12:54 PM   #5
Water Treatment
Akpsdvan's Avatar
Bottom line is a manual for the valve, it really does not matter the company name on the valve or the size of the tank. It is all about the valve and How that part is programmed and works along with a parts list.
Old 01-07-2016, 01:08 PM   #6
Rewards Points: 20
Yeah - after looking at the diagram in the manual it is identical. Thanks for posting this, I am sure it will prove to be a valuable resource.
Old 01-20-2016, 06:50 AM   #7
Rewards Points: 20
Just wanted to let you know I had gotten everything sorted out. Thanks again for all of your help!
Weird shower/tub faucet handle and water flow problem daluu Plumbing 1 01-19-2014 09:08 AM
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
