Icemaker Install - No Access To Copper Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-22-2016, 08:06 PM   #16
Rewards Points: 125
Re: Icemaker install - no access to copper pipe
The paper tag on the faucet supply line says iron pipe, so I think it must be that, not compression.
But I need a valve on the 1/4" port. I could go from the 1/4" tee outlet, to a 3ft supply line, to a 1/4" needle valve, to a 10ft supply line. But that seems really clunky. I'd rather not have a valve dangling around on a hose under there.
llamafilm is offline   Reply With Quote
Old 03-22-2016, 08:10 PM   #17
A "Handy Husband"
rjniles's Avatar
Rewards Points: 806
The tag is referencing the connection to the wall pipe.
My electrical answers are based on 2017 NEC, you may have local amendments.
Removing pipe wrap from 1/2 inch copper pipe steve3847 Plumbing 8 04-19-2015 08:33 AM
Install new faucet with compression fittings to larger copper supply lines cwb124 Plumbing 7 02-27-2013 04:11 PM
Septic Odor from Hole in Copper Pipe kita123 Plumbing 1 04-03-2012 08:22 PM
Copper to Black Pipe Gas Connection dwolek HVAC 1 03-15-2010 05:02 PM
Copper pipe size question greymous Plumbing 18 01-30-2009 04:02 PM
