Icemaker Install - No Access To Copper Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-22-2016, 12:21 PM   #1
Rewards Points: 125
Icemaker install - no access to copper pipe
I want to add a line for my new fridge ice maker from the kitchen sink. Under the sink, there is copper pipe extending from the drywall only about 1/2", where it meets the shutoff valve. Without cutting the drywall open, is there a secure and legal way to do this?
Removing the the shutoff valve means shutting off the water for my whole building, which includes 5 other units. Can I add some kind of tee after the shutoff valve? Then the sink and ice maker would share one valve, but that seems fine to me.
llamafilm is online now   Reply With Quote
Old 03-22-2016, 12:26 PM   #2
Rewards Points: 114
There are adapters that fit over the copper pipe, than once secured it will puncture the copper pipe allowing the water to flow into you fridge line, I'm not sure what it's called though. I think it comes in a kit
Chrisathome is offline   Reply With Quote
Old 03-22-2016, 12:38 PM   #3
Rewards Points: 125
Re: Icemaker install - no access to copper pipe
I think you're talking about a saddle valve. There is not enough room to install one on the copper pipe here. Also, from what I've read they are prone to leak, and maybe against code. I live in Los Angeles, but I can't find anything specific about saddle valves in the local code.
Old 03-22-2016, 01:13 PM   #4
Rewards Points: 5,498
Yes, you can do that.
The Following 2 Users Say Thank You to SeniorSitizen For This Useful Post:
Fix'n it (03-22-2016), oh'mike (03-22-2016)
Old 03-22-2016, 02:15 PM   #5
Oso954's Avatar
Rewards Points: 1,600
I would tee it after the existing valve, then add a valve on the the line to the fridge. That way you can shut it off, if needed, without impacting the water supply to the sink.
Oso954 is offline   Reply With Quote
Old 03-22-2016, 02:39 PM   #6
Rewards Points: 2,560
There are shut-offs available that allow for you to feed different downstream items.
One example:
http://www.lowes.com/pd_272815-143-K...d=3191041&pl=1
bob22 is offline   Reply With Quote
Old 03-22-2016, 02:42 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 18,174
^^THAT^^ is the best way to go.
ddawg16 is online now   Reply With Quote
Old 03-22-2016, 02:53 PM   #8
Rewards Points: 125
Now that I think about it, if I ever replace the fridge with a non-ice making one, it would be great to have separate valves. So I think I'll do a tee and two valves.
Old 03-22-2016, 03:17 PM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
No need to remove existing valve. Google ice maker tee.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 03-22-2016, 04:04 PM   #10
Rewards Points: 125
I tried looking for icemaker tees, but can't find any the right size. I'm surprised this is so difficult.
https://www.plumbingsupply.com/quick-tee-adapter.html
These products sound great. But I need 1/2 comp x 1/2 comp x 1/4 comp, and that doesn't seem to be an option.
Old 03-22-2016, 04:24 PM   #11
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
That is a weird size, most kitchen faucet stops (shutof valve) are 3/8" Show us a picture of the stop under your sink,
Old 03-22-2016, 04:50 PM   #12
Rewards Points: 114
Yes the saddle valve is what i was talking about, I didn't realize they were prone to leaking, but if it wont fit for your setup than it doesn't matter. definitely provide a picture so we can better help you.
Old 03-22-2016, 06:27 PM   #13
Rewards Points: 125
Oops, my mistake. The shutoff valve is actually 1/2" MIP. Here's a photo. So I'm looking for a tee with 1/2" FIP inlet, 1/2" MIP outlet, and valved 1/4" compression outlet.
Old 03-22-2016, 07:44 PM   #14
Rewards Points: 114
Would something like this work? it's all i can find when i research it:
http://www.homedepot.com/p/Homewerks...3C-Z/203444236
Check out all of my home improvement projects at http://www.homerenovationsandtools.com
Old 03-22-2016, 07:59 PM   #15
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Your valve looks like 1/2 compression output not MIP. The tee you linked in post 14 should do it. You could also add another stop on the 1\4 port.
Removing pipe wrap from 1/2 inch copper pipe steve3847 Plumbing 8 04-19-2015 08:33 AM
Install new faucet with compression fittings to larger copper supply lines cwb124 Plumbing 7 02-27-2013 04:11 PM
Septic Odor from Hole in Copper Pipe kita123 Plumbing 1 04-03-2012 08:22 PM
Copper to Black Pipe Gas Connection dwolek HVAC 1 03-15-2010 05:02 PM
Copper pipe size question greymous Plumbing 18 01-30-2009 04:02 PM
