I Have Just Bought A New Home - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2016, 10:07 AM   #1
Rewards Points: 8
I have just bought a new home
and have one of these radiators:
https://www.tradscastironradiators.c...ng/liberty.jpg but I can hear a lot of knocking.
How do I go about bleeding it? because its not a normal radiator and I don't know where to begin :/
It's cast iron and I'm not sure if I'm supposed to do anything differently??
Martin12345 is offline   Reply With Quote
Old 02-02-2016, 10:15 AM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
when you say knocking, do you mean from the piping below the floors, that looks like a hot water radiator, they usually dont knock , but the pipes can creak if they are tight against any wooden beams...
WhatRnsdownhill is offline   Reply With Quote
Old 02-02-2016, 10:19 AM   #3
Rewards Points: 8
like a banging noise when it fills with hot water.
Old 02-02-2016, 10:31 AM   #4
are you sure its hot water and not a 2 pipe steam system?
Old 02-02-2016, 10:42 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,054
Ayuh,... I could be wrong, But,....
It appears there's a bleeder in the top right port plug,....
Old 02-02-2016, 10:53 AM   #6
air in a radiator shouldnt cause a banging sound..more like a gurgling noise...
Old 02-02-2016, 12:15 PM   #7
Rewards Points: 3,230
Welcome to the forum Martin.
As mentioned, just want to verify, is this a hot water or steam system? Thanks. I'm assuming it's a regular hot water system with radiators you're talking about.
Actual pictures of the radiator in question and pictures of the boiler set-up will help as well. Thanks.
jmon is offline   Reply With Quote
Old 02-02-2016, 12:21 PM   #8
Congratulations on buying a new home Martin. Is this home brand new or new to you?
If brand new, there should be some type of builders warranty on it. One of your options may be to start there. Let them fix it on their dime. Just a suggestion.
Oh! 1st home! Closing in two weeks! 30 Pics! Firefighter3244 General DIY Discussions 29 07-02-2014 08:03 PM
Coleman DGAA mobile home furnace issue baluna HVAC 9 04-07-2012 08:55 AM
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
How to optimize thermostat settings (2 heating systems same home) rossl56 HVAC 1 11-26-2008 03:39 AM
