I Can't Figure Out How To Remove This Kitchen Faucet! - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-12-2015, 11:57 AM   #1
Rewards Points: 6
Question
I can't figure out how to remove this kitchen faucet!
My kitchen faucet it leaking under the counter and seems to be coming out the center hole then running down the sprayer hose. There is also a dripping sound in the drain after I've use the water that lasts for a long time. The leaking subsides when the water is not being used.
I've replaced faucets before, and it's not really that hard, but I'm having the devil of a time trying to figure out how to remove this one. I cannot find any mounting nuts. I'm going to try to post a link/picture.
It's a single lever faucet... Peerless, I think.
dedex13 is offline   Reply With Quote
Old 12-12-2015, 12:11 PM   #2
Rewards Points: 1,844
Humm... I'm looking at a left and right nut bolt in that picture... Perhaps those be the ones.
Ghostmaker is online now   Reply With Quote
The Following User Says Thank You to Ghostmaker For This Useful Post:
dedex13 (12-12-2015)
Old 12-12-2015, 12:25 PM   #3
Rewards Points: 76
Yep the clamps are the two nuts with wings on the left and right holes.
ponch37300 is offline   Reply With Quote
The Following User Says Thank You to ponch37300 For This Useful Post:
Old 12-12-2015, 01:17 PM   #4
Rewards Points: 6
Thank you! I had made an attempt to remove them, but it was far too difficult to get a grip on them with pliers and since they were half-way down the bolt I didn't think it could be what was holding the whole thing in. I see it now though, so thank you.
Of course, it has now stopped leaking...
The Following User Says Thank You to dedex13 For This Useful Post:
oh'mike (12-12-2015)
Old 12-12-2015, 04:26 PM   #5
A basin cock wrench would make your life easier.
throrope (12-13-2015)
Old 12-12-2015, 05:18 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Isn't there a threaded brass nut on the center stud?
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 12-13-2015, 09:05 AM   #7
Thats a moen single handle with a side mount spray kitchen.
Old 12-13-2015, 12:33 PM   #8
Rewards Points: 276
If that's a Moen, I'm surprised you have issues. Every one I've installed was the last one needed and Moen is the only one I buy. While the this may not be worth the effort especially if the finish suffered the wear and tear of time, Moen guarantees internals for life and provides replacement. The last ones I installed came with a sticker with model number that I stuck on the back wall under the sink.
throrope is offline   Reply With Quote
Old 12-13-2015, 12:59 PM   #9
Rewards Points: 5,422
We can only imagine how much time and frustration would have been saved if a couple of minutes had been devoted to applying a dab of grease to some fitting threads and bolt threads.
Yep, it may seem good things take too much time at the moment but usually save much more time and frustration in the end.
SeniorSitizen is offline   Reply With Quote
Old 12-13-2015, 08:17 PM   #10
Rewards Points: 1,038
nearly all people just cannot fathom how correct you are. i use white grease.
Fix'n it is offline   Reply With Quote
Srewless faucet handles..anyone know how to remove this one? bobfrommtl Plumbing 3 01-03-2015 06:40 PM
no hot water at kitchen faucet....all others are fine. ideas? tarheelblue Plumbing 10 12-28-2014 11:55 PM
Bronze kitchen faucet with stainless steel sink? Juniper94 Kitchen & Bath Remodeling 2 11-29-2014 05:08 PM
Kitchen Faucet Is Leaking Sycamore Inn Plumbing 23 11-14-2011 03:49 PM
