I Cannot Undo Faucet Handle To Repair Leak - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By COLDIRON
Old 01-13-2018, 07:40 PM   #1
Rewards Points: 2
I cannot undo faucet handle to repair leak
Hi all, i have a leaky faucet and figured out which handle the leak is coming from when i turned the water off. Problem is i cannot figure out how to remove the handle. It doesnt have a screw embedded, i have tried twisting the top part of the handle, the base while holding the handle, and prying either top part or thee base. My guess is the base needs twisted because the design is similar to those that are removed that way, but i cant get it to twist by hand or with tape covered channel wrench. Has anyone seen this handle and give any tips please?
I cannot undo faucet handle to repair leak-20180113_181559.jpg   I cannot undo faucet handle to repair leak-20180113_181604.jpg   I cannot undo faucet handle to repair leak-20180113_181618.jpg
Klinc702 is offline   Reply With Quote
Old 01-13-2018, 07:45 PM   #2
Rewards Points: 3,430
Re: I cannot undo faucet handle to repair leak
Welcome to the forums klinc
Looks like you have a lot of sediment build-up. Try some vinegar and baking soda or clr and scrub brush.
Sometimes that sediment can be a bear. Really makes things hard to remove.
Looks like you have some really hard water. You on a well?
jmon is offline   Reply With Quote
Old 01-14-2018, 06:32 AM   #3
Rewards Points: 2,074
If you know the manufacturer of the faucet IE: Kohler, Delta, Glacier Bay ETC.
You can go on line and look at all their pictures and pick out the one you have then look up the number from there and call or send the manufacturer the number or picture they will give you all the information you need. It's a pain but it works. I always deal with the manufacture's they are more than happy to assist and even send parts free many times. U Tube also works.
Gregsoldtruck79 likes this.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 01-14-2018, 07:08 AM   #4
hkstroud's Avatar
Rewards Points: 6,694
Will either one of the balls on the end of the handle turn. They may indeed be screws caps.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 01-14-2018, 08:04 AM   #5
Guapo
Rewards Points: 11,950
Or after you shut the valve, spin the faucet as if you were turning on the water but don't stop turning it.
Guap0_ is offline   Reply With Quote
Old 01-14-2018, 08:48 AM   #6
After looking at the pictures again I thought I noticed something. On the back of the handle ( in the last image) it looks like a set screw unless it's just a image shadow.. Just sayin.
faucet handle won't come off pkhalsa Plumbing 9 06-20-2011 08:39 AM
Right tool to remove cartridge of single handle bath sink faucet? darsunt Plumbing 2 05-20-2011 10:01 AM
Faucet handle faces the wrong direction. diyntn Plumbing 1 04-22-2009 08:09 PM
deciphering faucet handle EdPDX Plumbing 1 11-05-2008 07:12 AM
Repair outdoor faucet? mx13 Plumbing 3 04-09-2007 06:08 PM
