Hydro Jetting And Flexible Couplers - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-15-2015, 12:18 PM   #1
Rewards Points: 322
Hydro Jetting and flexible couplers
I have never seen any discussion of possible damage to flexible couplings (fernco, etc) from hydro-jetting. It is pretty common to use these couplings to join cast iron/abs/pvc/clay sewer lines. Depending on what is being joined there may be only a 1/4" gap of exposed coupler or it may be much more if there is a size difference. If a high pressure water jet can cut roots, is there a risk of damaging a flexible coupling?
tns1 is offline   Reply With Quote
Old 03-15-2015, 01:25 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 240
Yes, there is.
When I used to run a jetter occasionally, I used a camera also so I could see exactly where my root head was.
Old 03-16-2015, 05:46 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 1,012
Jetter can cause lots of damage if not used properly, down here have a a bunch of morons pretending to know plumbing and drain cleaning destroying homes pipes our local Roto rooter is number one in giving any shulp a jetter an turning them loose.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 04-08-2015, 10:50 AM   #4
Rewards Points: 322
I spoke with someone at Fernco. He said that they have many thousands of installed couplings, and that hydro-jetting has not shown to pose any significant problems as long as you don't linger right on the coupling. Common sense would suggest that extreme pressures or special attachments such as flails or root cutters would require extra care.
Old 04-09-2015, 09:40 PM   #5
Master Plumber
Javiles's Avatar
Anytime you see a gap in a fernco type coupling connection your asking for trouble never mind the jetting.
