How To Update This Plumbing In A Tight Space - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-15-2016, 11:58 AM   #1
Rewards Points: 18
How to update this plumbing in a tight space
I'm remodeling my laundry room, and the existing plumbing situation in there is...bad.
I need to replace the washer hookups, and add proper hookups for a wash sink. I'd like to set it up like this
But the space is too tight to get the existing T off. I've considered starting over and replacing all my plumbing with pex, but I've got a very short crawl space with the plumbing buried behind insulation...a project for another time.
I could maybe leave the old T in place, and cap off the existing faucet spot - I'd like to place a T a few inches higher to clear the drain pipe.
Thoughts and advice?
Thank you!
CapnGreenJeans is offline   Reply With Quote
Converting Vented Crawl Space to Unvented/Conditioned Achille76 Building & Construction 4 02-19-2013 09:10 PM
Crawl space insulation question gregsenne Insulation 11 01-16-2013 03:26 PM
how to cut a hole in tight space boogerz General DIY Discussions 16 05-14-2011 01:56 PM
Crawl space moisture/water removal KAdams4458 Building & Construction 7 04-24-2011 12:21 PM
how to pick the right toilet for a tight space? ilyaz Kitchen & Bath Remodeling 1 05-27-2010 02:59 PM
