How To T Off Galvanized Pipe For Fridge? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
Old 01-14-2018, 11:17 AM   #1
Rewards Points: 276
How to T off galvanized pipe for fridge?
My house has galvanized pipe. The plan is to replace it with pex but for now I am living with it. Some things are pex partially.
My washer plumbing is currently ran to the kitchen so my washer is right next to the fridge. I want to t off the washer cold line and run it to my fridge with a cut off valve in between.
The hot is pex but the cold is galvanized. How can I t off it to fridge?
I know this seems like a simple question but most fittings are copper and I don't want to put copper on that galvanized pipe directly. I was thinking dielectric union but I don't want to solder anything and all they have here is stuff you have to solder.
The pipe is 1/2 and the fridge line in 1/4.
Thanks.
wagoner is offline   Reply With Quote
Old 01-14-2018, 11:49 AM   #2
retired framer
Rewards Points: 15,742
Re: How to T off galvanized pipe for fridge?
Just for temporary I would remove the cold hose and install it with a Y fitting and adapt one side down to the 1/4" and the other side to the washer.
Old 01-14-2018, 12:05 PM   #3
Rewards Points: 6,600
Is there a reason you want to use the cold galvanized rather than the pex hot?
SeniorSitizen is offline   Reply With Quote
Old 01-14-2018, 12:10 PM   #4
Rewards Points: 276
What are the down sides to doing that?
Old 01-14-2018, 12:51 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 904
I run my ice maker on the hot supply. I am on a well and I find the WH precipitates out some of the mineral buildup.
The ice maker uses so little water it never sees actual hot water.
Sent from my RCT6213W22 using Tapatalk
SeniorSitizen likes this.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 01-14-2018, 12:59 PM   #6
Rewards Points: 276
Thanks. This is ice maker and water spout on fridge. So wondering if I'd be getting glasses of warm water.
Old 01-14-2018, 03:06 PM   #7
Ours doesn't and it's common to supply with the hot side for reasons stated previously + any sediment with a specific gravity greater than water like rust flakes from galvanized pipe will drop out in the water heater.
But you can do a test of your own to determine how much water from the hot source reaches the ice maker / ice water termination point before hot actually gets there. Depending on your plumbing that can vary between summer and winter of course but I suspect would be negligible.
Old 01-14-2018, 03:31 PM   #8
Rewards Points: 276
All right. I will tea off of the hot side. What kind of fittings should I get to connect off that PEX?
Old 01-14-2018, 04:55 PM   #9
Rewards Points: 18,998
If it was mine I'd be Teeing off that line and installing a real ice maker box so I'd have a shut off right at the wall.
https://www.homedepot.com/p/Eastman-...0233/205852291
mark sr likes this.
Old 01-14-2018, 07:01 PM   #10
Rewards Points: 276
This is just temporary so I don't want to do all that right now. These lines aren't in the wall anyway. It has two lines coming up through the floor with those large shut off knobs like you would see on a hose faucet. I just need to T off of that PEX line and add a shut off valve in between and then connected to the fridge.
Just wondering the best fittings / way to do that. Eventually I'll do it right but for now I just need a solution.
Old 01-14-2018, 08:00 PM   #11
Rewards Points: 3,494
Sharkbite fittings will work with pex.
Any big box store sell sharkbite ice maker installation kits requiring no soldering, or gluing etc. Just cut pipe and push on.
https://www.homedepot.com/p/SharkBit...5024/206105353
Please post some pics so we can see what will work for you. Thank you.
jmon is online now   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
wagoner (01-14-2018)
Old 01-14-2018, 08:53 PM   #12
Rewards Points: 276
It's pretty straightforward. Just a PEX pipe coming up through the floor with 1/2 inch fitting clamped onto it and then I shut off valve into that fitting.
https://imgur.com/gallery/TBH8j
Old 01-15-2018, 03:51 PM   #13
Rewards Points: 276
I just realized my other link went no where.
https://imgur.com/a/37Ju0
Old 01-16-2018, 08:54 AM   #14
Rewards Points: 2,074
I would never hookup an ice maker water line to hot water line. Just like a dishwasher I would never hook it up to a cold water line. Just saying.
Nealtw likes this.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 01-16-2018, 10:39 AM   #15
Rewards Points: 276
I really don't want to. I was thinking about just Ting off with galvanized for now. The female piece on the end of my fridge line is brass though.
Cutting Galvanized Pipe m1951mm Plumbing 26 07-08-2017 10:10 PM
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
how close can PVC waste pipe be to galvanized hot water pipe pwaterm2 Plumbing 2 02-17-2015 07:53 AM
is it possible to use a compression shut off on Galvanized 1/2" pipe? Limit54 Plumbing 8 04-11-2010 09:24 PM
burying galvanized steel pipe amakarevic Plumbing 9 08-19-2008 10:37 AM
