How To Seal A Pipe Through 6 Mil Plastic - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-26-2015, 05:19 AM   #1
Rewards Points: 4
How to seal a pipe through 6 mil plastic
I have a wood box I'm using to hold water with 6 mil plastic as a liner. About 4 inches from the bottom I need to drill a hole (for a drain pipe...1" pvc) through the side of the wood box and also through the plastic liner. How can I seal the plastic liner around the pvc drain pipe? Is there a mechanical way to do this(ie: using threaded pipe and large washers), or a sealant of some kind that would work? Any ideas?
John
jbclem is offline   Reply With Quote
Old 09-26-2015, 07:21 AM   #2
Rewards Points: 6,580
I would use a bulk head fitting or if I didn't care to have a hole in the box and conditions were conducive I may also just place a siphon hose over the top into the water the distance I wanted to drain.
Old 09-26-2015, 02:39 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 290
The image senior showed should be available in PVC at a good hardware store. They are used for water heater pans.
Old 09-26-2015, 06:54 PM   #4
Rewards Points: 4
Thanks for the idea...looks like it would work if I can find one with a wide enough lip to cover the plastic around the hole I cut...and I'll have to cut a fairly precise hole in the plastic (I'm going through a double layer of 6 mil).
John
Old 09-26-2015, 06:57 PM   #5
Rewards Points: 18,990
Plastic liner and a wood box is just a very poor way to do this.
Why not a cheap cooler?
Is this the right drainage pipe maddog1 General DIY Discussions 19 05-08-2014 08:46 AM
Need advice on rusted pipe problem silencer Plumbing 16 12-02-2012 08:59 AM
PVC or CPVC pipe cement steve3847 Plumbing 7 11-17-2012 05:50 PM
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
Exterior Furnace exhaust vent pipe NeedHomeRepair HVAC 1 12-20-2010 05:17 PM
