How To Save A PVC Fitting - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-12-2015, 04:08 PM   #1
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,125
I bought two 1 1/2 inch PVC shutoff valves from Ace, to plumb a hot tub. I glued them in place with the new type Gorilla Glue, no primmer or cleaner needed, they say. All went well yesterday, today both of the shutoff valves are leaking dead center on the bottom of the valve, they are both defective.
One shutoff valve is in a really hard to get to place and will take me hours to change out. The bad thing is that PVC fittings is glued into the one that is screwed directly into the pump. That fitting can not be bought at any hardware store as it is a special fitting that came with the pump.
It will take a week or so for the new fitting to get here. I have seen on youtube that PVC pipe can be removed from a fitting with heat and a pair of pliers.
Have any of you ever tried that, will it damage the fitting?
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 12-12-2015, 05:16 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
I've never had luck with PVC valve. Use threaded brass ball valves with PVC male adapters. And I always use separate primer and cement.
My electrical answers are based on 2017 NEC, you may have local amendments.
The Following User Says Thank You to rjniles For This Useful Post:
joecaption (12-12-2015)
Old 12-12-2015, 06:02 PM   #3
Retired Moderator
Rewards Points: 7,174
Jim, there is a cutting bit called ' ram bit' that will easily cut a pipe out of a fitting---
But I do not know if it would cut out a valve end from a fitting.
Old 12-12-2015, 06:18 PM   #4
An old Tradesmen
Rewards Points: 9,218
Those bits are only for getting the pipe out of the fitting. Not saving the pipe like Jim wants to.
The Following User Says Thank You to beenthere For This Useful Post:
oh'mike (12-12-2015)
Old 12-12-2015, 07:01 PM   #5
Ole Wood Worker
BigJim's Avatar
RJ, I won't have anything to do with a PVC valve again either.
Mike, the the second and third video shows removing pipe from a fitting with heat. I really don't have a lot to loose trying it with heat except for several hours replacing all that is messed up right now.
I have a Bosch heat gun I think will work. The only thing I want to save is the fitting that screws onto the pump and a Tee that the shutoff is glued into, I don't care about the valve, Ace will give me two other valves and they won't be PVC. LOL
Jim
The Following User Says Thank You to BigJim For This Useful Post:
Old 12-12-2015, 07:47 PM   #6
Rewards Points: 3,130
I'm with Big Jim. PVC valves are almost universally junk. If the valve itself doesn't fail, the handle breaks off.
The Following User Says Thank You to md2lgyk For This Useful Post:
BigJim (12-12-2015)
Some ways to save money, and do PMs BigGuy01 Building & Construction 5 12-23-2011 02:46 PM
Easiest way to go from 1/2" ball valve to 1/4 inch compression fitting? Studly Plumbing 11 11-03-2011 07:57 AM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 05:30 PM
Cracked PVC fitting in concrete DJupin Plumbing 6 07-29-2008 03:12 PM
