How To Remove Tub Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-10-2016, 05:50 PM   #1
Rewards Points: 4
How to remove tub faucet
I am trying to remove a Delta faucet from my tub.i have looked and. there is no set screw to loosen and I have tried turning it clockwise and it will only turn a little bit. I'm afraid to try to turn it more.
There's a little notch on the bottom, but there is no screw in it. There is a little white plastic tab, but it doesn't seem to do anything. Is there some other way to remove a faucet?
Catyp is offline   Reply With Quote
Old 05-10-2016, 06:11 PM   #2
Rewards Points: 18,760
Re: How to remove tub faucet
Most often if there's a notch there's a screw, never seen a white tab, got a picture? To remove it would need to be turned counter clock ways, lefty loosy.
Old 05-10-2016, 06:34 PM   #3
Rewards Points: 4
Here's a picture of the faucet I am trying to remove
Old 05-10-2016, 07:04 PM   #4
Rewards Points: 226
I think you mean a tub spout, not faucet . Anyway , you may need to use a pipe wrench to turn it counter clockwise .
daveblt is offline   Reply With Quote
Old 05-10-2016, 07:24 PM   #5
Rewards Points: 3,202
If you are sure there is no set screw, try inserting one handle of the pliers or channel lock into the spout and carefully use that as leverage. Turn ccw.
May be some sediment preventing it from breaking loose. Use some wd 40 or clr. Also make sure there is no silicone around the spout and tile. Looks like there may be some on the top. Hope you get it off soon.
jmon is offline   Reply With Quote
Old 05-10-2016, 07:41 PM   #6
Retired Moderator
Rewards Points: 7,174
It is possible that the spout was twisted by someone and the set screw is no longer at the bottom ,where it should be--Deltas use set screws--at least the ones I have installed.---and some have a brass fitting that is soldered to the copper stub out.
Need a tool to remove a sink faucet 1-1/2" nut mystic_cobra Plumbing 6 08-26-2015 07:20 AM
Hard time to remove old Kohler kitchen faucet handyman999 Plumbing 4 09-13-2012 03:46 PM
how to remove tough price phister kitchen faucet? darsunt Plumbing 5 06-24-2010 11:48 PM
problem: remove bath faucet rjw_mpwr Plumbing 2 06-05-2010 02:55 AM
REMOVE worn out STEM TYPE shower faucet... Wafot Plumbing 1 07-04-2009 07:58 PM
