How To Remove Shower Pan? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-11-2016, 01:55 PM   #16
Rewards Points: 1,002
You have a lot of patience.
I would just get myself some $1/square foot tile and some densshield and some urethane grout and rip out those walls, pull the pan, examine it, replace if necessary, and re-build the shower. Use the Laticrete liquid product or the Red Guard or the Aqua whatever to waterproof your seams.
cleveman is offline   Reply With Quote
Old 01-11-2016, 02:19 PM   #17
http://mustee.com/product-lines/show...ors/index.html
Take a look at the shower floors, particularly the door seal kit and the drain seal kit. They are at the very bottom.
Old 01-11-2016, 03:06 PM   #18
Rewards Points: 6
cleveman,
Thanks for all your help! That is what I plan to do. I was just being very cautious when trying to remove the shower pan as to not break any existing piping.
I can tell you now, that the builder did not install the GapSeal-Pro. Not sure if that is required or not. BUT this builder did take short cuts as we had a major leak in the basement cause by faulty flanges.
Thanks again! Most helpful!
timnancyk is offline   Reply With Quote
How to remove brass drain flange from fiberglass shower pan scottyv81 Plumbing 21 09-23-2012 01:03 PM
How to remove soldered cap on my bathroom shower flange? ohman Plumbing 7 09-15-2012 12:08 AM
how to remove a 20 year old delta shower handle mcvrlje Plumbing 2 06-27-2011 07:10 AM
How do I remove round shower stems? cmineer Plumbing 2 06-08-2011 10:04 PM
Stained Shower Base- Remove Stain Law Building & Construction 1 09-27-2010 05:21 AM
