How To Remove Roman Tub Spout With No Access To Set Screw - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-19-2016, 04:55 PM   #1
Rewards Points: 2
How to Remove Roman Tub Spout with No Access to Set Screw
It looks like whoever installed my Jacuzzi tub did so after the Kohler roman faucet was installed. Now there is hardly any room to access what looks like the set screw that is pointing toward the raised Jacuzzi tub (1/4" gap). Any thoughts on how to remove? Is a hacksaw the only way?
Thanks.
lind777 is offline   Reply With Quote
Old 05-19-2016, 05:29 PM   #2
Rewards Points: 1,860
Re: How to Remove Roman Tub Spout with No Access to Set Screw
Drill it out.
Old 05-19-2016, 06:32 PM   #3
Rewards Points: 18,794
And how would anyone know without a picture so we can see what your seeing?
SHEPLMBR (05-24-2016)
Problem removing a tub spout EffinIllini Plumbing 6 04-03-2016 06:11 AM
Sheared head on Tapcon screw - how to remove? mkuether Remodeling 9 12-04-2008 08:18 PM
Bathtub Spout Leaks Behind Spout (pics) wallix Plumbing 7 10-14-2008 03:41 PM
how to remove roman bath faucet? tarheelblue Plumbing 1 06-07-2008 06:38 PM
Remove a screw gpowell52 General DIY Discussions 3 03-03-2008 03:57 PM
