How To Remove Kitchen Faucet Neck - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-02-2017, 12:23 PM   #1
Rewards Points: 48
How to remove kitchen faucet neck
Got a leak on the base of the neck.
Faucet is too close to wall so I cannot undo it by turning it. There is a ring on the bottom that does rotate, not sure if that is part of the process. No screw or tab to work with. Any ideas?
peequi is offline   Reply With Quote
Old 03-02-2017, 02:15 PM   #2
Rewards Points: 6,322
Re: How to remove kitchen faucet neck
Mine doesn't look exactly like that but the ring on mine screws off lefty loosie ( counter clock wise ) then the neck lifts up and off.
SeniorSitizen is offline   Reply With Quote
Old 05-18-2017, 09:58 AM   #3
Rewards Points: 48
Bump, still don't know how to take only the neck out!
Old 05-18-2017, 10:09 AM   #4
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,834
Might have to pull the entire faucet....
Who's the maker... might try their website for an exploded view.
(Or a recip saw with a metal blade....)
MTN REMODEL LLC is online now   Reply With Quote
Old 05-20-2017, 05:38 AM   #5
Rewards Points: 2,632
A good mystery! Please write back when you get the answer.
bob22 is offline   Reply With Quote
Old 05-20-2017, 06:39 AM   #6
Rewards Points: 281
Probably needs a new O-ring inside.
Have you looked at all the sides, including the side underneath the handle? There might be a very tiny socket screw.
Druidia is offline   Reply With Quote
no hot water at kitchen faucet....all others are fine. ideas? tarheelblue Plumbing 10 12-28-2014 11:55 PM
Bronze kitchen faucet with stainless steel sink? Juniper94 Kitchen & Bath Remodeling 2 11-29-2014 05:08 PM
Delta kitchen faucet is leaking under the sink grave20 Plumbing 2 04-01-2012 01:00 PM
Selecting a New Kitchen Faucet klumbsy Kitchen & Bath Remodeling 4 02-25-2011 08:29 AM
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 05:10 AM
