How To Remove This Kitchen Faucet? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By joed
  • 1 Post By RRH
Old 09-02-2017, 08:16 AM   #1
Rewards Points: 6
How to remove this kitchen faucet?
I have replaced faucets before but I have never seen one like this, and I can't find a brand name on it anywhere. Can someone point me in the right direction?
John B H is offline   Reply With Quote
Old 09-02-2017, 08:44 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,996
Re: How to remove this kitchen faucet?
Unscrew that long bolt and the funny shaped washer should come off allowing the faucet to pull out from the top.
Windows on Wash likes this.
Old 09-02-2017, 09:23 AM   #3
RRH
Rewards Points: 1,480
Yes just bend the copper pipes out of the way to make it easier. A rachet wrench or nut driver is easier to use.
That is a Pfister faucet I think. Most likely the Parisa model
RRH is offline   Reply With Quote
Old 09-02-2017, 09:43 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 286
Might help to disconnect the sprayer head/hose. You won't pull it through that hole....
Old 09-02-2017, 10:35 AM   #5
Rewards Points: 6
Thanks guys, got it out and it was easy. With my old eyes under the sink that looked round, not like something I could get a wrench on.
It all didn't fit out the hole. I hate working under the sink so I just pulled it up and cut it with a hacksaw.
Thanks again
Old 09-02-2017, 05:16 PM   #6
RRH
Thanks again
Just for net time. It would fit out the hole. Just remember it had to go in that way.
Yes, it does not look like it. But you just bend the lines in close and they all come out.
MTN REMODEL LLC likes this.
Old 09-02-2017, 06:10 PM   #7
Rewards Points: 6
I know you are right, but I would have had to get back under the sink and remove the flexible hose extendors that were not part of the original faucet.
And the hole was small. To small for the replacement fauctet. Thankfully I had a drill bit the right size to drill through the granite countertop.
Loose Kitchen Faucet - Single Spout Moen Klammern Plumbing 2 07-01-2015 05:50 PM
no hot water at kitchen faucet....all others are fine. ideas? tarheelblue Plumbing 10 12-28-2014 11:55 PM
Delta kitchen faucet is leaking under the sink grave20 Plumbing 2 04-01-2012 01:00 PM
kitchen design: should we remove inner wall(s)? ilyaz Kitchen & Bath Remodeling 4 10-26-2010 07:59 AM
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 05:10 AM
