How To Remove A Drop-in Porcelain Sink Under A Countertop? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-30-2014, 06:20 PM   #16
Homerepairguy's Avatar
Rewards Points: 1,114
Originally Posted by Koolhaas View Post
They are glued, and should be braced with either a diagonal wood brace or if you have a good installer, they will use mounting brackets. Most i've seen are only glued! The adhesive is pretty strong.
I have heard of under-mount sinks falling out too!
The under-mount sink mounting method shown in the video using metal clips is a good method. The silicone bead is actually only to prevent leaks, and is not the method of support.
Under-mount sinks just glued is total nonsense IMO.
Thanks,
HRG
Homerepairguy is offline   Reply With Quote
Old 12-31-2014, 09:14 AM   #17
Rewards Points: 80
Thanks,
HRG
I think it's nonsense too! It just happens a lot.
Koolhaas is offline   Reply With Quote
Old 12-31-2014, 06:01 PM   #18
Rewards Points: 1,930
If I may say so myself. What a feces covered builder. The under mount sinks I have seen have been directly secured to the counter top with epoxy. Also the counter top guys install that sink at there business. Granite top guys usually add support brackets.
Honestly I would start saving for a complete new top. Doubtful that you will remove that in a useable fashion.
This time use a higher quality sink no more porcelain on steel type.
The Following User Says Thank You to Ghostmaker For This Useful Post:
oh'mike (12-31-2014)
drill porcelain sink for soap dispenser? wkearney99 Plumbing 7 09-19-2013 07:39 PM
sealing new sink against laminate countertop darsunt Remodeling 3 12-08-2011 08:19 PM
cutting ovel for drop in sink in culture marble lem22 Building & Construction 1 03-11-2010 12:47 PM
Removing old countertop sink in bathroom virginia Building & Construction 1 08-23-2009 02:00 PM
Caulking around kitchen sink deeaa Remodeling 8 07-13-2008 03:12 PM
