How To Protect The Water Well Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-22-2017, 05:32 AM   #1
Rewards Points: 26
How to protect the water well pipe?
Need another advice. I have to bring the water line and wire from the water well to the house site at 4' in the ground and is quite a long way. To protect them, I was thinking to run into a conduit/pipe or o-pipe. Do you have another idea? May I put it together in the conduit? The water line is 1.25" so the plan is to use 3" conduit/o-pipe. Do, you see any potential problem?
Thank you for any suggestion.
rogerius is offline   Reply With Quote
Old 04-22-2017, 09:37 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 32,010
Re: How to protect the water well pipe?
If protection is goal then lay some 2x planks over top of it. Put some sand in the trench over the pipe, add the lumber, add some more fill, add some caution/warning tape and then fill the rest of the trench.
Old 04-22-2017, 12:24 PM   #3
Water Treatment
Akpsdvan's Avatar
Rewards Points: 1,184
Freeze goes how deep?
Here the water line is at least 10 feet down and covered by blue board then the wire line is laid down.
Metal pipe?
Akpsdvan is offline   Reply With Quote
Two Tankless Water heaters on same pipe? dasadab Plumbing 4 03-16-2015 12:02 PM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
Water Pipe Calcs - Interesting Result ddawg16 Plumbing 0 05-30-2012 11:19 AM
Basement drain pipe "pit" ground water fix. alecmcmahon General DIY Discussions 13 12-01-2010 05:42 AM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 09:54 PM
