How To Prepare Drain For Tile Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-11-2016, 05:17 PM   #1
Rewards Points: 16
How to prepare drain for tile shower
I tore out a fiberglass shower stall and will be replacing it with a tile shower. The drain is sticking out of a roughly 1'x1' hole in the concrete. What's the best way to deal with this hole and the drain before adding pre-slope? Do I need to mix quikcrete to fill in the hole and make it level with the floor? Can I just fill the hole with what I use for the pre-slope?
I assume before I fill the hole, with either quikcrete or pre-slope, that I need to cut the drain pip so the bottom flange of the drain (like the one pictured) will be flush with the concrete floor before any pre-slope, is that correct?
How to prepare drain for tile shower-2016-02-07-19.55.38.jpg   How to prepare drain for tile shower-2d75b409-1afc-4fba-b8b0-83e4d08c750e_1000.jpg
bphillips921 is offline   Reply With Quote
Old 02-11-2016, 05:58 PM   #2
Rewards Points: 32
ya if it is all concrete fill it in so its level. But first you will want to attach the drain with the right glue(abs or pvc), figuring out the right height so that the bottom/widest flange sits on top of the subfloor(concrete in this case). You can be a little high (1/8 to 1/4) since the pre slope can be fenagled under it to create solid backing. then you will do your preslope and lay down the shower liner.
surfing_santa is offline   Reply With Quote
Old 02-11-2016, 06:54 PM   #3
Rewards Points: 16
Thank you very much!
Old 02-11-2016, 10:23 PM   #4
Rewards Points: 16
Got it done tonight. Drain might be slightly high, but I can just put a little more pre-slope down.
Thanks for the help.
Adding new shower drain to toilet drain? w layout pics BNR34RB26DETT Plumbing 25 02-11-2015 09:55 PM
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
First shower install, drain help please! tigerbalm2424 Plumbing 6 01-16-2008 05:44 AM
