How Much Room Above Hot Water Heater? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-09-2015, 08:37 PM   #1
Rewards Points: 269
Hello,
How much room should I provide above my hot water heater? Would one foot be enough space for installation and maintenance?
The unit is connected to my geothermal AC system, so no venting duct is required (similar to a solar hot water heater).
The reason that I am asking is that I am building a shelf for my well water pressure tank and it will sit above the hot water heater. Yes, the shelf will be quite robust and rated for 1500 pounds. There is also a 14 foot ceiling to cram everything under, but not very much space laterally.
Peace,
Dr. Z.
Zeigh is offline   Reply With Quote
Old 12-10-2015, 07:35 AM   #2
Rewards Points: 1,602
They make segmented anode rods now, but I would still leave at least 2-3 feet above.
mikegp is offline   Reply With Quote
Shopping for New Electric Water Heater Lots of Questions LeakyHawaiiRoof Plumbing 3 11-02-2014 01:18 AM
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 08:48 PM
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 02:35 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
