How To Identify This Delta Shower Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-31-2016, 08:01 PM   #1
Rewards Points: 442
How to identify this Delta shower valve
I'm trying to figure out how the cap pops off this valve so I can remove it. I tried prying but don't want to damage it. Anyone recognize it?
How to identify this Delta shower valve-image_1470013239577.jpg   How to identify this Delta shower valve-image_1470013268297.jpeg
zootjeff is offline   Reply With Quote
Old 08-01-2016, 06:26 AM   #2
Rewards Points: 18,762
Re: How to identify this Delta shower valve
That chrome cap should just pop off where it meets the gold rings.
Delta will likely send you any needed repair parts for free if you contact them with those pictures.
http://worldwide.deltafaucet.com/cus...rts/index.html
Old 08-01-2016, 06:27 AM   #3
Rewards Points: 5,452
Consider trying one of their customer service contact methods. They may allow you to send your picture.
https://www.deltafaucet.com/customer-service
Old 08-01-2016, 06:34 AM   #4
Rewards Points: 8,299
The units inside the wall are pretty much the same; only the trim varies so a) either the cap pops off or b) there is an exposed set screw somewhere on the handle.
For this one , I am going with b. I've found a utility knife with a dull blade to be a great tool for getting the cap started. Run it around the seam and then pry gently.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is offline   Reply With Quote
Old 08-01-2016, 11:24 PM   #5
Rewards Points: 442
Any idea if the cap is on the outside or the inside of the gold band?
Old 08-02-2016, 06:33 AM   #6
Read Joe's post above. I've not done one but that is the logical place.
Colbyt
Best PEX tubing size for shower valve? Studly Plumbing 4 05-22-2013 06:53 PM
soldering copper pipe on a shower mixing valve. Ed911 Plumbing 7 05-17-2012 09:27 AM
Delta scald guard shower valve leak pdamania Plumbing 1 03-08-2011 05:45 PM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 06:46 AM
Mystery shower valve: Can anyone identify?? HELP! Tonz Plumbing 3 03-07-2008 03:04 PM
