How Heavy Is A Concrete Laundry Tub? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-03-2014, 04:32 AM   #1
Homerepairguy's Avatar
Rewards Points: 1,114
How heavy is a concrete laundry tub?
We have an old single compartment concrete laundry tub that looks kind of like this one (including the stand):
Although all of the water pipes on our property are copper, the hot and cold water pipes to this laundry tub are galvanized. I think what happened is when my Dad built our laundry room addition 30 years ago, he used galvanized pipes since that's what he had on hand.
Anyway, the cold water galvanized pipe right behind the faucet developed a leak due to corrosion. I need to move the laundry tub to open up the double wall to replace the galvanized pipes with copper pipes.
Any retired plumber out there that knows about how much a single compartment concrete laundry tub weighs?
Thanks,
HRG
Homerepairguy is offline   Reply With Quote
Old 12-03-2014, 04:37 AM   #2
Retired Moderator
Rewards Points: 7,174
About 70 pounds is a guess---Not to bad moving a single bowl sink like that--
Old 12-03-2014, 01:19 PM   #3
Rewards Points: 1,938
Still much more fun to break it up with a sludge hammer...
Old 12-03-2014, 01:39 PM   #4
Rewards Points: 1,414
More than 70, less than 200. I moved one that felt ~150 the other day, but it was a double. So probably under 100, anyway.
Tom738 is offline   Reply With Quote
Old 12-03-2014, 06:57 PM   #5
Rewards Points: 10,798
Measure it. Google Concrete weight calculator.
If its 32" x 30" x 24" tall on the outside, with 2" thick walls, its 7000 cubic inches and weighs 575 pounds.
SPS-1 is offline   Reply With Quote
Old 12-03-2014, 07:38 PM   #6
Rewards Points: 6,412
With a length of 2x4 lumber and bath scales you can weigh it.
Old 12-03-2014, 07:52 PM   #7
kwikfishron's Avatar
Rewards Points: 460
I didn't do any math but there's no way that the sink pictured weighs even close to 575 lbs.
kwikfishron is online now   Reply With Quote
Old 12-03-2014, 08:06 PM   #8
Its easy to figure out the weight if its measured and you do the math. Without that, we are all taking WAGs. But figure if its made from 5 of these Lowes patio stones (4 sides plus bottom), its 400 pounds
Old 12-03-2014, 08:28 PM   #9
Plumber
TheEplumber's Avatar
Some of those old sinks are actually soap stone.
Google says around 20 lb/sq ft.
My concern is the flimsy legs. Don't let them fold up on you!!
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ChiTownPro (12-07-2014), gregzoll (12-03-2014)
Old 12-03-2014, 08:29 PM   #10
Doc Sheldon's Avatar
Rewards Points: 400
Not too many bath scales will go that high, I'm betting. Probably closer to 300# than 200... had one similar to that, was 1.5 inch thick... I moved it, but I couldn't get it up into the pickup without help.
Doc Sheldon is offline   Reply With Quote
Old 12-03-2014, 08:43 PM   #11
Something wrong in what you googled. Weight should be per cubic foot, not per square foot. Soapstone seems to be heavier than concrete.
The one in my parent's old house is a double with walls about 3" thick. It aint going anywhere.
Old 12-03-2014, 08:53 PM   #12
Rewards Points: 400
Dang! That's a lot of kin per cubic shaku!
Old 12-03-2014, 10:53 PM   #13
We'll only be weighing half of it + half the stand weight X 2
Old 12-04-2014, 01:16 AM   #14
oh'mike, Ghostmaker, Tom738, SPS-1, SeniorSitizen, kwikfishron, TheEplumber and DocSheldon (hope I didn't miss anyone),
Thanks all for your replies.
SPS-1 came up with a good idea about using an online concrete calculator that I didn't think of doing.
Measuring the 4 walls and assuming that the bottom is also 1.2 inches thick like the walls, using an online concrete calculator I came up with 134.8 lbs.
Oh and thank you TheEplumber for the warning about the legs folding up on me. The legs are old and a little rusty so I can see that happening. I would have overlooked it without your warning.
Thanks again,
HRG
The Following User Says Thank You to Homerepairguy For This Useful Post:
TheEplumber (12-04-2014)
Old 12-04-2014, 01:42 AM   #15
I've come up with an idea for moving the laundry tub that I'd like to run by you guys.
The tub's drain goes into a trap and then the pipe runs horizontally into the double wall. It's made out of black ABS.
I'm thinking about removing the drain completely from the tub and then using an automotive floor jack and a piece of 2x6 lumber under the tub. Raise the tub to remove weight off the legs and then cut the leg assembly so I can remove the legs. (As TheEplumber pointed out, the legs are flimsy anyway so no loss cutting to remove them.)
I might have to use additional lumber on top of the jack to attain the height needed if the jack cannot go up high enough. Then lower the tub all the way down and use the automotive floor jack to move it since the jack has wheels.
When reinstalling the tub, jack it back up and install a new leg assembly made out of an old bed frame. I think I can assemble the bed frame leg assembly by bolting it together. I'll use stainless steel bolts. Then lower the tub on the new bed frame legs.
If you see any kinks in my plan please let me know,
HRG
Concrete prep for outdoor tile onthejob Concrete, Stone & Masonry 8 03-29-2012 12:34 PM
Polished and Unpolished Concrete Floor Questions pretzels Flooring 5 03-05-2012 03:27 PM
Laminate on Concrete Floor OK & Heavy Piano??????????? sfagtjt Flooring 5 05-23-2011 09:51 AM
pics of new concrete with lines from garbage can amandalc04 Building & Construction 17 05-23-2010 04:58 PM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
