How To Hang PVC Pipe For Reduced Noise? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-10-2016, 01:02 AM   #1
Rewards Points: 331
Question
How to hang PVC pipe for reduced noise?
I am in the process of replacing a section of bad cast iron with PVC pipe. The 4" pipe will be hanged vertically and there's about 8 feet of it, with a turn in the middle.
I've read PVC is louder than cast iron and sometimes it can happen that the weight of the water as it flows through the pipe can cause noise, I assume some of that is hanger noise.
What do you guys use to hang PVC pipe, and how do you reduce noise? I've checked out rubber coated split rings but they seem expensive. I have some galvanized plumber's tape, would that be OK? Home Depot sells Plastic-Coated Pipe Hangers so that may be another option?
Deck is offline   Reply With Quote
Old 08-10-2016, 07:01 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 258
Re: How to hang PVC pipe for reduced noise?
PVC can be hung with either method you mentioned. Then you insulate the pipe for noise.
If you replace the bad pipe with new cast iron noise won't be an issue. The hanger selection has little effect on water noise in this case
The Following User Says Thank You to TheEplumber For This Useful Post:
Deck (08-13-2016)
Old 08-10-2016, 09:28 AM   #3
Rewards Points: 1,526
I had the joist bay (under the toilet) insulated with fiberglass insulation. Then the down pipe went through the kitchen/family room. I had the 3" pvc pipe boxed in, not through the wall. So I had room to encase the pipe with can foam at least 1" all around. I could hear the toilet flushing but not the water rushing through.
The foam runs, esp when hot outside, so this has to be done in small lifts. If running through the wall and don't have room for foam, should use iron pipe as suggested. Go to pro store, if not homedepot, and ask if they will cut it for you. Grinder can cut and make small adjustments. The remaining iron sections must be supported independently before/after replacement.
carpdad is offline   Reply With Quote
The Following User Says Thank You to carpdad For This Useful Post:
Deck (08-13-2016)
Old 09-20-2016, 11:17 PM   #4
Rewards Points: 331
I ended up using one galvanized strap as an experiment to see how it is and I haven't heard anything from the strapping. I figured I would hear pings or something but nothing so far. I will install some more now and I will skip insulating the pipe. This is in a basement room where the above joists are insulated, so I'm sure that helping block noise going to the above room. You can see a picture in this post.
Tags
plumbing , pvc
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
2" pipe on above sink in wall rusted out in a spot bryanp22 Plumbing 9 02-23-2012 08:29 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
Exterior Furnace exhaust vent pipe NeedHomeRepair HVAC 1 12-20-2010 05:17 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
