How To Flush Shower Valve Without Making A Mess? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-21-2016, 11:27 AM   #1
Rav
Rewards Points: 892
I have an old Standard Re-Nu shower stem that I'm planning on removing and either repairing or replacing. While it's removed I want to flush the valve. Problem is that the valve seat is recessed into the wall a few inches, and I think that after I remove the stem and barrel that when I turn the water on again that it would gush out and into the wall cavity, as well as out into the shower. I've attached a picture of the stem in the wall, and one of what the stem will look like once I remove it. Any suggestions on how to flush the valve without making a mess? Thanks.
How to flush shower valve without making a mess?-image-4092456191.jpg   How to flush shower valve without making a mess?-image-1843826242.jpg
Rav is offline   Reply With Quote
Old 06-21-2016, 07:49 PM   #2
Rewards Points: 18,808
Re: How to flush shower valve without making a mess?
If you really think you need to do this turn the water on for about 30 seconds, it's going to shoot out away from the wall, what little drips is not going to do any harm.
Rav (06-21-2016)
Shower Valve & Head Depth 325_man Plumbing 6 07-11-2014 08:41 PM
soldering copper pipe on a shower mixing valve. Ed911 Plumbing 7 05-17-2012 09:27 AM
Shower valve for rainshower head Liv Plumbing 0 03-29-2012 10:41 AM
New shower valve, no hot water? Chris112 Plumbing 0 03-19-2011 06:21 PM
Shower valve installation sydni2009 Plumbing 3 09-21-2010 05:04 PM
