How To Fix Minor Leak In Drain Pipe ? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By Gregsoldtruck79
  • 1 Post By kulkarnipb
Old 03-11-2018, 02:20 PM   #1
Rewards Points: 26
how to fix Minor Leak in Drain pipe ?
I noticed today a a minor leak in the big black drain pipe ( see images ) where it is attached to basement wall .
Any idea what material shall I use to fix it ? Since there is water in it, I need something which can stick on watery surface.
Thanks in advance. Any help is appreciated .
how to fix Minor Leak in Drain pipe ?-20180311_150116.jpg   how to fix Minor Leak in Drain pipe ?-20180311_150126.jpg
kulkarnipb is offline   Reply With Quote
Old 03-11-2018, 02:55 PM   #2
Rewards Points: 88
Re: how to fix Minor Leak in Drain pipe ?
Try some FlexSeal products as a fix, not a cure. .
jmon likes this.
Gregsoldtruck79 is offline   Reply With Quote
Old 03-11-2018, 04:19 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 31,952
Looks like a wall leak not a pipe leak. How deep is it on the outside? I would dig up the outside, clean and seal it.
Old 03-11-2018, 04:24 PM   #4
Rewards Points: 3,452
Agree with greg. Try some flex seal.
It looks like silicone was used the last time. Probably worked for years. Not much you can do until your ready to fix it correctly. Imo, leak doesn't look that bad, I would just try the flex seal.
As far as a permanent fix; tough one. Looks like the pipe moved out of greenish housing going through the concrete by a good 1/4 inch or so. Possibly due to a settling issue. idk.
Stand by for more advice from the plumbers.
jmon is offline   Reply With Quote
Old 03-11-2018, 05:01 PM   #5
Rewards Points: 26
Thank you all. Let me try with flex seal.
Sent from my SM-N950U using Tapatalk
Old 03-11-2018, 05:41 PM   #6
Rewards Points: 1,251
How deep in the ground is it? If it's not too deep, sealing it from the outside would be best.
Cleaning it up real good on the inside and wrapping with butyl rubber roll flashing would work as well if the flex seal gives you any trouble.
KHouse75 is offline   Reply With Quote
Old 03-11-2018, 06:01 PM   #7
Rewards Points: 26
Thanks for reply. It is almost 4 to 5 ft below ground from outside. So I am preferreing to fix from inside.
Old 03-11-2018, 09:15 PM   #8
Super Moderator
joed's Avatar
Upon closer look it appears the black pipe passes through the foundation in a sleeve of green pipe. Clean as much of the old caulking/glue etc. off as you can and apply some new sealant. Squeeze as much as you can into the crack between the two pipes.
Old 03-11-2018, 10:34 PM   #9
JUSTA MEMBER
Rewards Points: 3,882
As others have already advised, that flex-seal does work very well.
Clean the area very well, of all the old silicone, dirt, water, and anything else.
Dry it well, and the spray can is the easiest to use, but they make other methods, if you want to try them, a liquid that you brush on, a caulk tube, and even a wide tape.
I was skeptical of the stuff, until I tried it, with nothing to lose but the price of a can, I tried it and my leak sealed, and has been trouble free for 4 years now.
ED
de-nagorg is offline   Reply With Quote
Old 03-12-2018, 07:42 AM   #10
Rewards Points: 26
ED
Perfect. Thanks . I am going to use flex seal. :-)
de-nagorg likes this.
Old 03-12-2018, 09:11 AM   #11
JUSTA MEMBER
I forgot to add, use a few thin coats, spaced out over a few days, instead of one thick coat, you will get better results that way.
ED
Tags
basment , drain , leak , sewer
Can't drain water from water pipe to outside faucet hansim4 Plumbing 19 02-23-2015 02:07 PM
Basement Framing And Drain Pipe blainekehl Building & Construction 9 02-21-2015 09:14 AM
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 01:53 PM
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 03:05 PM
New bathroom drain pipe leaks PAK Plumbing 2 07-29-2008 09:36 AM
