How To Fit Slightly Misaligned 4" Pvc Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree6Likes
  • 1 Post By Nealtw
  • 1 Post By hkstroud
  • 1 Post By TarheelTerp
  • 1 Post By dtbingle
  • 1 Post By Nealtw
Old 04-25-2019, 08:38 PM   #1
Rewards Points: 414
How to fit slightly misaligned 4" pvc pipes
Had 4" sump line clog up under the front yard. Dug it out and found the 4" SCH 30 PVC from the house was connected to the 4" SCH 40 PVC storm drain with a rubber fernco coupling. However, the pipes seem to have shifted vertically leaving a height difference of about 2".
I tried using a coupling and just inserting new pipe in slightly crooked, but couldn't get enough height. Then trying to use 2 45 fittings overcorrected by about 2". I can get them together with a shielded coupling, but it's obviously crooked, and to the point where I wouldn't feel good leaving it that way.
What's the best way to handle slightly misaligned 4" pvc pipes?
One thought was the 4x 90 fix, but that seems excessive?
dtbingle is offline   Reply With Quote
Old 04-25-2019, 09:15 PM   #2
Rewards Points: 414
Re: How to fit slightly misaligned 4" pvc pipes
EDIT: whoops...must be tired. 4x 90 fix would be a terrible idea for a sump drain line
Old 04-25-2019, 09:39 PM   #3
retired framer
Rewards Points: 12,172
Several cuts 3/4 way thru will allow it to bend, Wrap that with rubber and apply 2 SS clamps.
de-nagorg likes this.
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
The Following User Says Thank You to Nealtw For This Useful Post:
dtbingle (04-26-2019)
Old 04-25-2019, 10:44 PM   #4
hkstroud's Avatar
Rewards Points: 5,340
Suggest that you pick up a 4" long ninety, insert a short piece of pipe in it. Hold that along side of the existing short ninety and pipe. Chances are that you will be able to cut the vertical pipe below the existing short ninety and make horizontal pipe align with the other horizontal pipe. If so that will also let you connect the horizontal pipes with a coupling.
MTN REMODEL LLC likes this.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
The Following User Says Thank You to hkstroud For This Useful Post:
Old 04-26-2019, 06:48 AM   #5
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,012
...but it's obviously crooked, and to the point where I wouldn't feel good leaving it that way.
Good for you.
You did an unplanned repair job.
Now you get to PLAN repiping that section altogether.
Dig out enough soil to expose more pipe.
Johnny_inFL likes this.
TarheelTerp is online now   Reply With Quote
The Following User Says Thank You to TarheelTerp For This Useful Post:
Old 04-26-2019, 07:59 AM   #6
Rewards Points: 1,087
So will heating it up (heat gun), without the leakage risk of perforating it...is heating PVC drain pipe a no-no?
huesmann is online now   Reply With Quote
Old 04-26-2019, 08:05 AM   #7
retired framer
It is just a drain not a sewer and it isn't under pressure,
Old 04-26-2019, 09:08 AM   #8
Rewards Points: 414
All good ideas, thanks. The idea of cutting off the existing short 90 seems like my top solution assuming there's enough of a straight section underneath to cut and glue the new longer 90 too.
Might also see if 2x 22.5 degree fittings will give right height correction vs the 2x 45s.
hkstroud, you mentioned using an actual pvc coupling to tie in the horizontal run leading up to the house and the short 90 that goes go to storm drain line. If this line had shifted that much over time, my thought is that a shielded fernco coupling would allow a little flex in the joint vs. a hard glued pvc coupling just breaking off. In fact, in my second picture, it almost looks like that's exactly what happened to the broken end of the pipe. Thoughts?
Nealtw likes this.
Old 04-26-2019, 09:54 AM   #9
Rewards Points: 414
Slightly off-topic, but what do you all do as far as backfilling around this area? Sand? Whatever native soil that was dug up? Crushed stone?
Old 04-26-2019, 10:16 AM   #10
retired framer
Sand, it makes for easy digging the next time, while it is best for protecting the pipe.
Old 04-26-2019, 10:23 AM   #11
retired framer
Who know, some one makes a dog leg fitting.
https://www.google.ca/search?biw=102...=1556291651036
lenaitch likes this.
Old 04-26-2019, 05:43 PM   #12
hkstroud's Avatar
Thoughts?
Remember you ask.
I agree that the freezing and thawing of the ground is probably what broke the horizontal line. I assume that the vertical line is attached to the storm sewer and cannot move. The horizontal line does not appear to be buried very deeply. With each freeze the horizontal line is moved up slightly. With the thawing the line does not move back down because of the compaction of the soil. With the next freeze it moves upward a little more. How long this has been happening is hard to tell. However, it will continue until the horizontal line is either buried below the frost line or comes out of the ground.
Next thought is that a 4" line is far to big for a sump pump line. A 2" line would be quite sufficient.
I would excavate the horizontal line as far back as practical. Excavate around the vertical line deep enough to put on a 4x3 coupling and a 3" 90 degree elbow. Ream out the inside of the 4x3 coupling so the 3" line will pass through it completely. Install the 4x3 coupling on the vertical line with glue. Insert a length of 3" PVC through the 4x3 coupling as far as possible. Do not glue. The purpose of the 4x3 coupling is to keep the soil out only. Install a 3" ninety and pipe between it and the original 4" horizontal line with 3" PVC. Connect the two with another 4x3" coupling.
This will allow for the upward movement of each freezing.
Until you bury the horizontal line below the frost line or you stop the ground in Michigan from freezing, that line is going to continue to moving upward. This approach will allow it to do so.
Just my thoughts.
PS
There is such a thing as a inside pipe cutter for cutting that vertical line.
Harold,
Old 04-27-2019, 05:11 PM   #13
Rewards Points: 414
hkstroud, that all makes sense and I completely agree with you.
However, I finished up the repair last night before reading your reply haha. Ended up cutting below that 45 coming from the storm sewer and extending to be the correct height, then connected the two ends together with a shielded coupling.
And as you mentioned, the 4" line is overkill for the sump. I could go all of the way back to the house rather easily, but don't think it's worth it to pull up good pipe. Also, this might worth out in my favor and allow us to attach an outlet for a planned french drain nearby without having to worry about capacity.
I have this posted in my other thread about sump pump lines, but this is how it was originally plumbed near the house.
The plan is to run new 3" Sch 40 under the driveway and tee up above grade. The 1.5" from the sump pump inside will come out and go into this 3" pipe with an air gap. Then the 3" line will go under the driveway and extend a foot or two into the front yard, and then make the transition into the existing 4" line down to the storm drain.
Nealtw likes this.
Old 04-29-2019, 08:36 AM   #14
Hopefully the clamps on that coupling are stainless!
Did I just ruin my copper pipes with steel wool? ghutch Remodeling 1 10-09-2013 07:02 AM
Insulating water pipes outside home? daluu Insulation 9 01-11-2013 12:11 AM
Original (?) galvanized water supply pipes replace with PEX, CPVC, copper? TomServo Plumbing 5 11-06-2012 11:07 PM
Replace Steel pipes with Copper thinkfuture Plumbing 2 10-30-2012 12:48 PM
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 07:22 AM
