How Is This Even Possible? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-16-2016, 01:40 PM   #1
Rewards Points: 625
How is this even possible?
Everything was working fine and I had both hot and cold water but I plan on replacing an outdated vanity in the 1st floor guest bathroom with a new pedestal sink so I went under the vanity and shut off the old hot and cold water valves. They were a little tight and took a while to shut off but after working them back and forth by hand, I shut them off. I went outside and shut off the main at the house, came back in and removed the old water lines under the sink from both valves that I shut off.
No leaks, no problems...
Everything is back together, both valves under vanity and main are turned on and I get NO WATER (hot or cold), NOTHING, NADA coming out of the sink but it DOES drip occasionally.
a1481155 is offline   Reply With Quote
Old 02-16-2016, 02:19 PM   #2
Rewards Points: 5,572
That's when I would do what I call a 50/50 check. Shut the valves under vanity back off, disconnect lines and turn valves back on to determine if there is water flowing through H / C stop valves. If there's flow the problem of course is toward the new equipment. If not problem is the other direction - 50/50 odds .
The Following User Says Thank You to SeniorSitizen For This Useful Post:
JERRYMAC (02-17-2016)
Old 02-16-2016, 02:31 PM   #3
Rewards Points: 18,790
#1, If they where that stuff then the right thing would have been to replace them with new 1/4 turn valves while the water was off.
Another simple thing to check the the aerator to see if it's plugged up with trash from messing with the lines.
The Following 3 Users Say Thank You to joecaption For This Useful Post:
de-nagorg (02-16-2016), JERRYMAC (02-17-2016), Yodaman (02-16-2016)
Old 02-16-2016, 03:17 PM   #4
WhatRnsdownhill's Avatar
Rewards Points: 2,220
do you have water in the rest of the house?
WhatRnsdownhill is offline   Reply With Quote
The Following User Says Thank You to WhatRnsdownhill For This Useful Post:
Old 02-16-2016, 04:21 PM   #5
JUSTA MEMBER
Rewards Points: 3,196
As Joe points out.
often shutting off these valves dislodges CRUD buildup inside the line, then when the water is turned on the crud plugs the aerator.
ED
de-nagorg is online now   Reply With Quote
Old 02-16-2016, 07:02 PM   #6
Rewards Points: 625
Thanks!
This may be a stupid question but what if water starts flowing again with no lines attached...How do you keep it from shooting out and going all over the place? And FWIW, there's no new equipment, yet. I just put everything back the way it was, for now.
Old 02-16-2016, 07:09 PM   #7
Property Mgt/Maint
Rewards Points: 8,184
answer this first
[political signature removed]
Yodaman is offline   Reply With Quote
Old 02-16-2016, 07:17 PM   #8
Rewards Points: 625
Never said the rest of the house was affected...
So yes, I have water in the rest of the house.
Old 02-16-2016, 07:28 PM   #9
Property Mgt/Maint
remove and clean the aerator next,
test with it removed
Old 02-16-2016, 07:39 PM   #10
Rewards Points: 625
What is the aerator, how do I remove it and clean it?
Old 02-16-2016, 07:46 PM   #11
Originally Posted by a1481155 View Post
Thanks!
Unless I'm really confused about the set up you have, you should be able to control water flow with the stop valves.
Old 02-16-2016, 07:55 PM   #12
Property Mgt/Maint
its the little round screen that the water passes thru as it exits the faucet. May need pliers to loosen it
https://www.google.com/search?q=aera...aerator+faucet
Old 02-16-2016, 07:57 PM   #13
Super Moderator
Gymschu's Avatar
Rewards Points: 506
Yodaman described it, here's a pic:
"In the heat of battle, my father wove a tapestry of obscenity........."
Old 02-16-2016, 08:38 PM   #14
Rewards Points: 625
Thanks!
No bullsh*t, sometimes it amazes me how simple the fix can be...
You all ROCK!
