How To Escalate A Persistent Plumbing Issue? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree4Likes
  • 1 Post By fireguy
  • 1 Post By SeniorSitizen
  • 2 Post By rjniles
Old 01-19-2020, 01:08 PM   #1
Rewards Points: 228
How to escalate a persistent plumbing issue?
Hello, I am curious for some insight into a persistent plumbing issue I have had at my apartment building, namely that a certain kitchen sink drain line persistently backs up.
It seems to be grease (we snake, clear the drain, but never really recover a culprit), and then a month goes by and it needs to be snaked again. I suspect I need to spring for a more thorough drain cleaning, but I am not sure how to request it and make sure I know what I am getting. I dont want to call a plumber and say "snake the main drain line" and have that not be the correct thing to do for the situation. Typically all are satisfied with just unclogging the thing. I would be too if it would stay unclogged.
Any insight would be appreciated, thank you.
DIYHero is offline   Reply With Quote
Old 01-19-2020, 01:12 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 1,290
Re: How to escalate a persistent plumbing issue?
Don't do chemicals. Do the manual cleaning, but let the apartment management know of the problem. It is up to them to contact a plumber and get it taken care of since they own the building. Anything you do will put you in jeopardy and they could hold you liable for damages. First thing is to cut back on things like grease and solids going down the drain. Run boiling water down the drain for starters, it may help soften the greasy stuff and help wash it on down.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 01-19-2020, 01:15 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 30,530
We used to get the kitchen lines in the cafeteria jet cleaned once or twice year. It is a high pressure line with a special nozzle that blasts all the grease off the pipe sidewalls.
The problem may not be in your lines but the mainline for the whole building.
Old 01-19-2020, 02:16 PM   #4
Rewards Points: 2,688
Kitchen sinks are notorious for that. i've Had that issue before. clear the lines as mentioned, then started using bio-clean, never had any more issues with clogged kitchen sink drain.
Not promoting it or saying that it will work for you, but it did work in my case.
jmon is online now   Reply With Quote
Old 01-19-2020, 03:06 PM   #5
Rewards Points: 994
When I was cleaning 5 or 6 resturant exhaust systems a week, I used Bio-Clean in slow drains. The stuff works!
jmon likes this.
fireguy is offline   Reply With Quote
The Following User Says Thank You to fireguy For This Useful Post:
Ghostmaker (01-20-2020)
Old 01-19-2020, 03:39 PM   #6
Rewards Points: 3,608
Cleaning habits of greasy kitchen houseware items must be changed for a long term solution. We have our snake sessions down to every 13 years and if the wife wasn't so hard headed about it it would be close to never needing a snake again.
Bondo likes this.
Old 01-19-2020, 04:10 PM   #7
Rewards Points: 1,634
You are in an apartment shouldn't your management be dealing with this?
Ghostmaker is online now   Reply With Quote
Old 01-20-2020, 12:26 AM   #8
Rewards Points: 1,002
It is against many plumbing codes to discharge water at boiling temperature to a drain pipe.
Old Thomas is offline   Reply With Quote
Old 01-20-2020, 05:37 AM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 224
How do you drain your pasta?
Sent from my RCT6A03W13E using Tapatalk
huesmann and 123pugsy like this.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 01-21-2020, 03:25 PM   #10
Rewards Points: 228
Yea i am management. We've had several plumbers but frankly i would like to shop around and am curious what to say. right now they say theyll unclog it, which is not sufficient.
Will bio clean clean further down the line? Just local clogs i use a hand snake.
Old 01-21-2020, 03:26 PM   #11
Rewards Points: 228
Yep thats me.
Old 01-21-2020, 03:28 PM   #12
Rewards Points: 228
Sounds promising. Is that a common service a plumber would provide? Do I just request a jet cleaning, or is there a more recognized name for the process?
Old 01-21-2020, 04:13 PM   #13
Super Moderator
joed's Avatar
It is a common thing for drain cleaning services. Just ask to have your drain line jetted or jet cleaned.
The Following User Says Thank You to joed For This Useful Post:
DIYHero (01-21-2020)
