How Do I Solder Ball Valves. - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree7Likes
Old 05-16-2017, 05:36 AM   #16
Rewards Points: 1,054
Re: how do I solder ball valves.
Originally Posted by joed View Post
If using threaded how do you control the angle the valve handle ends pointing?
Measure and cut two 3/4" copper pipe stubs and sweat them into 3/4" male threaded fittings. Let cool and install them into the ball valve with pipe dope and teflon tape. Wrap the ball valve with a wet rag and sweat the unit into the pipes for the water heater. I do the same thing for replacing the main shut off valve for the house.
clarenceboddick is offline   Reply With Quote
Old 05-16-2017, 08:56 AM   #17
Super Moderator
joed's Avatar
Rewards Points: 31,922
Originally Posted by hkstroud View Post
I think it was just a fluke. Or more likely, if you purchase the valve at a big box store like Home Depot, someone screwed with it and then returned it to the store.
It happened to two valves. Lucky the store has a good return policy. I will get the threaded ones next time.
I think they are cheaply made big box valves.
It might be a cheap valve. A good one should cost $10 or so.
They weren't cheap. $12 each.
C-PVC ball valves french_guy Plumbing 3 02-05-2016 06:54 AM
Shut off valve placement ? Kenneth M Plumbing 5 01-17-2016 07:02 PM
How long are 1/4-turn ball valves supposed to last? Druidia Plumbing 9 05-18-2015 07:31 AM
which Ball Valves for potable water? agoodboy Plumbing 5 04-05-2013 08:40 PM
check out the new ball valves! wombosi Plumbing 7 02-03-2009 09:00 PM
