How Do I Protect This Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-01-2016, 09:50 AM   #1
Freedomsand's Avatar
Rewards Points: 304
How do I protect this drain?
French drain and sump pump in cellar, goes out through foundation and through a pipe to a hole in the front lawn. I have this drain in the front lawn (see photo). Well, I know it is not a 'drain,' not sure what the proper word is.
I am xeriscaping the yard, will be putting down cardboard and 4 inches of mulch. What do I do to protect this? Thank you.
Freedomsand is offline   Reply With Quote
Old 10-01-2016, 12:11 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 12,468
Re: How do I protect this drain?
Raise it up with a riser and perforate the riser for drainage.
Old 10-01-2016, 01:09 PM   #3
Rewards Points: 304
Please explain, what is a "riser" where do I find one, maybe can you post a photo of it? Do I have to remove the top before I put on this "riser." All I am finding are stair risers. No idea what you mean, thank you.
Old 10-02-2016, 09:03 AM   #4
Rewards Points: 304
Please clarify (per above post) what is a riser? All I am finding are stair risers. Thank you.
Old 10-02-2016, 09:47 AM   #5
A riser is a short length of pipe to accommodate the change in grade (i.e. soil/mulch height).
Old 10-05-2016, 03:20 PM   #6
Rewards Points: 304
So. I've been to both Home Depot and Lowe's. They only carry pipe up to 4 inch diameter. I need 6 inch. Where do I find this, anyone?
Old 10-05-2016, 03:48 PM   #7
Look for a local plumbing supply store.
http://www.homedepot.com/p/VPC-6-in-...06-2/202564459
Old 10-05-2016, 06:31 PM   #8
Rewards Points: 304
OK will look for a plumbing supply place.
That item is not available at any HD within 100 miles of me. And I couldn't see an option to buy it online, either. Phooey.
Old 10-06-2016, 12:56 AM   #9
hkstroud's Avatar
Rewards Points: 6,684
Have you dug around the outlet grill to see what size the pipe leading to it is? Bet is not 6".
hkstroud is offline   Reply With Quote
Connecting Wet Bar Vent and Drain LowlyDIYer Plumbing 1 09-12-2014 04:41 PM
What is this thing?? Todd54 Plumbing 10 05-09-2012 04:18 AM
Avoiding a frozen paver drain BrandonC_1972 Plumbing 2 04-28-2012 09:11 AM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
Condensor drain Captflx HVAC 6 08-17-2008 10:19 AM
