How The **** Do I Get This Off? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-31-2015, 09:37 AM   #1
Rewards Points: 6
Angry
How the **** do I get this off?
1" Granite Countertop
Recessed faucet nut
Too small for basin wrench
Too small for any other tool I can find
n8wing13 is offline   Reply With Quote
Old 08-31-2015, 11:00 AM   #2
GrayHair's Avatar
Rewards Points: 1,450
If a basin wrench is too big, maybe a socket driven open-end wrench like the one below (just to break it loose since you need 60 of movement to get to the next set of opposing flats). Add ratchet extensions as needed.
Or a flare-nut wrench. The problem with the flare-nut wrench is they all may be 6-point (60 again). I have taken a 12-point box-end wrench and used a die grinder to make a 12-point flare-nut wrench (30).
Any mention of codes is based on NFPA 70 and/or 72, as applicable, because they are the most widely adopted codes in the US. Local amendments may modify the code adopted in your area, so consult your local codes official.
GrayHair is offline   Reply With Quote
Old 08-31-2015, 11:08 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,287
Well for crying out loud, all the years I did mechanics and needed a line wrench and all I had to do is make one. I did buy a few of them but you know how a son is with your wrenches. LOL Thanks for the tip.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 08-31-2015, 12:35 PM   #4
JUSTA MEMBER
Rewards Points: 3,912
Me: I would remove all the attaching pipe and hoses, and things, and use a deep well socket the size of the nut, it is probably 1.25 or larger in size.
Looks to have been assembled the same way, from all the stuff up there.
ED
de-nagorg is offline   Reply With Quote
Old 08-31-2015, 12:40 PM   #5
Rewards Points: 144
http://www.homedepot.com/p/RIDGID-Fa...7018/100595073
mako1 is offline   Reply With Quote
Old 08-31-2015, 01:13 PM   #6
Rewards Points: 14
Same problem, i unhooked the drain and water supply, unbolted rhe counter and flipped it upside down.
Sent from my LGL41C using Tapatalk
pjmarkert is offline   Reply With Quote
Old 08-31-2015, 01:51 PM   #7
Rewards Points: 781
They have basin wrenches with smaller jaws. The one i have fits those nuts.
ct18 is offline   Reply With Quote
Old 08-31-2015, 05:06 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 258
Basin Buddy
http://www.homedepot.com/p/Husky-2-i...STC1/203336960
Old 08-31-2015, 06:48 PM   #9
Rewards Points: 582
never run into my basin wrench not working..may be slow coming off but it looks like it should come off....move the wrench at different angles ..even a small amount of movement will loosen it to where it will come off by hand...
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (08-31-2015)
Tags
granite , kitchen faucet , recessed countertop
