How Do I Get At This Fawcet Washer? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-10-2016, 08:47 PM   #1
Rewards Points: 4
How do I get at this fawcet washer?
See attached photo.
I don't know the make or model. Don't see any little hex screw. Tried pulling up, twisting base, can't figure out how to get at the washer to fix leaky fawcet. Please help!
fil512 is offline   Reply With Quote
Old 03-11-2016, 06:20 AM   #2
SHEPLMBR's Avatar
Rewards Points: 178
Looks like the bell part may thread off. Try that.
SHEPLMBR is offline   Reply With Quote
Old 03-13-2016, 12:51 PM   #3
Rewards Points: 4
Re: How do I get at this fawcet washer?
Good suggestion. But no dice. With enough force, the bell art does thread off, but it just bumps into the handle and can't go any further. I get about a 180 turn before running out of room. There must be a way to get the handle off before removing the bell art. I tried pulling really hard, but it doesn't pull straight up.
Old 03-14-2016, 06:19 AM   #4
SHEPLMBR's Avatar
Rewards Points: 178
weird
Old 03-14-2016, 09:01 AM   #5
WhatRnsdownhill's Avatar
Rewards Points: 2,220
put a screw driver between the handle and bell housing and pry up, long time ago handles like that use to snap onto a spring plastic clip..always said this will be a pita to remove..
WhatRnsdownhill is offline   Reply With Quote
Tags
fawcet , leak
Vibration In High Speed Spin Mode Davy49 Appliances 7 12-30-2014 09:47 AM
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 11:00 AM
bolt that holds the tank to the toilet bowl is leaking andrewjs18 Plumbing 13 04-06-2012 10:43 AM
Washer & Dryer Holiday Fun BRIANisMEisWE Appliances 8 12-24-2011 02:41 AM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
