How To Disconnect Gas T Connection - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-30-2015, 09:04 PM   #1
Rewards Points: 2
How to disconnect gas t connection
Hi all,
I am newb trying to replace DIY a gas control part for water heater that Rhreem sent me but having issue disconnecting the gas pipe.
Looking at videos online, seems simple enough, usually there is a clear connection screw/nut I can turn to take apart the T connection.l going to the gas control. However, in this case there is only the part that has the shut on/off valve that i can get a wrench on and Im not sure that is meant to be turned to unscrew since that is connected to the copper pipe.
I called around and getting quoted 300 dollars to do this, so Id like to do it myself if possible.
Thanks,
Dan
Replicator is offline   Reply With Quote
Old 09-30-2015, 09:55 PM   #2
Rewards Points: 5,348
As John Lee Hooker once said, Boom, boom, boom, boom. if you attempt this, you are a .....person with no common sense.
Ron
B. Franklin 1759
Old 09-30-2015, 10:02 PM   #3
Rewards Points: 2
Doh, my attachment I added on my Iphone didn't get posted.
Yes, I'm leaning on calling the pro in anyhow...
Old 09-30-2015, 10:09 PM   #4
Where do you live where copper pipe is used for natural gas?
Ron
B. Franklin 1759
Old 10-01-2015, 06:54 AM   #5
Retired Moderator
Rewards Points: 7,174
The control valve has three 'pipes' --one is the black 1/2" gas line---
One is the 1/4" pilot light feed tube
the third one is a thin copper thing that is the thermo couple---
A picture would help.
Google the service manual for that unit---a drawing will be part of that and will show you what is what.
jmon (10-01-2015)
Old 10-01-2015, 10:00 AM   #6
Rewards Points: 3,432
If there is no union after the gas shut off for water heater (there should be) you may have to turn main gas line off and break the pipe free from the closest union. Just a suggestion.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
oh'mike (10-01-2015)
Old 10-05-2015, 12:03 AM   #7
Rewards Points: 996
Is the supply line smooth pipe or does it have a crinkly, corrugated flex gas line? If so, is the manual gas shut off before the corrugated flex or after the flex line?
fireguy is offline   Reply With Quote
New Sundance Optima Spa connection DaveMcSF Electrical 11 08-27-2014 05:37 PM
Spa disconnect / GFI confusion among other things Maxian Electrical 4 11-09-2012 01:13 PM
Is voltage rating of 4-pole disconnect switch per pole? CDragon Electrical 5 11-07-2012 02:31 PM
Wiring Bridgeport Mill in Shop douglee25 Electrical 5 01-18-2011 08:17 PM
Telephone Jack Connection Problem jogan Electrical 9 04-20-2009 06:10 AM
