How To Cut PVC Straight - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree13Likes
Old 11-30-2019, 06:51 PM   #1
Rewards Points: 110
How to cut PVC straight
It always comes out slightly crooked when I use this method. Usually good enough for the job, but not perfectly straight. What's the better way?
Can I use a mitre saw?
farmerjohn1324 is offline   Reply With Quote
Old 11-30-2019, 06:53 PM   #2
retired framer
Rewards Points: 4,682
Re: How to cut PVC straight
chop saw, circular saw or jig saw will do a straighter cut.
Do not use flat bottom gables with scissor trusses.
Old 11-30-2019, 07:08 PM   #3
Rewards Points: 1,556
What Neil said.....but I’ve never seen a plumber use any of them. Normally a thick sharpie mark and recip saw and done. Sand the edges litely and good to go.
ront02769 is offline   Reply With Quote
Old 11-30-2019, 07:10 PM   #4
Naildriver
chandler48's Avatar
Rewards Points: 850
Miter saw........slooowly
MTN REMODEL LLC likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 11-30-2019, 07:10 PM   #5
Rewards Points: 110
Do they clamp it to something? I was just holding it with my hand.
Old 11-30-2019, 07:11 PM   #6
Rewards Points: 110
I've had PVC explode in the mitre saw before. But maybe the blade didn't have enough teeth.
Old 11-30-2019, 07:15 PM   #7
retired framer
Only because you were to nervous to hold it tight.
huesmann likes this.
Old 11-30-2019, 07:35 PM   #8
Rewards Points: 3,242
Build yourself a V block to lay the pipe in. When cutting by hand your shoulder and leg/hip should be directly in line behind the cut. A fine tooth blade with long even strokes usually produces the best result. A rip tooth saw preferred if you can find one. With a few practice cuts you'll look like an expert. For PVC I prefer a pull saw over a pusher because those prevents the operator from exerting excess pressure that causes crooked/wandering cuts.
Old 11-30-2019, 07:36 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 894
For 2" and smaller- https://www.amazon.com/Jones-Stephen.../dp/B005NITKPU
Works especially well on tubular PVC when assembing traps and contiuous wastes.
Larger pipe - https://www.amazon.com/Manual-Pipe-C...0SG9SSE6DZ4SFT
If you don't want to invest in these- use a sawzall with a fine wood or metal blade.
Avoid any thin blade that flexes
Old 11-30-2019, 07:36 PM   #10
Rewards Points: 110
Originally Posted by SeniorSitizen View Post
Build yourself a V block to lay the pipe in. When cutting by hand your shoulder and leg/hip should be directly in line behind the cut. A fine tooth blade with long even strokes usually produces the best result. With a few practice cuts you'll look like an expert. For PVC I prefer a pull saw over a pusher because those prevents the operator from exerting excess pressure that causes crooked/wandering cuts.
I probably would have done better if I had my large hacksaw. But it's in storage.
Nealtw likes this.
Old 11-30-2019, 08:02 PM   #11
Property Mgt/Maint
Rewards Points: 7,402
My miter saw is first choice if it's set up and convenient to use. But can cut it with practically any saw that you own. I did pick up this PVC saw many years ago and it still works good. This one is made by Starrett, but Lenox also makes one.
When using, assuming you get the cut started straight, it will finish straight. The depth of the blade makes it impossible for the blade to wander like a hack saw might.
SeniorSitizen and Tom153 like this.
[political signature removed]
Yodaman is online now   Reply With Quote
Old 11-30-2019, 08:16 PM   #12
CodeMatters's Avatar
Rewards Points: 7,360
Rolling the piece being cut makes for a straighter cut.
CodeMatters is online now   Reply With Quote
Old 11-30-2019, 08:31 PM   #13
Rewards Points: 824
Wiseman say 'level end with a belt sander, then hand finish with sandpaper'.
Found this in a fortune cookie.
Tom153 likes this.
diyorpay is offline   Reply With Quote
Old 11-30-2019, 09:45 PM   #14
Rewards Points: 618
Plumbers have a hand held battery operated shear that chops up to 2” pvc. If my chop saw is at the site, I use it but pvc sawdust is a pain to clean up. I cut outdoors and clean up with a leaf blower.
Old Thomas is offline   Reply With Quote
Old 12-01-2019, 06:36 AM   #15
Naildriver
chandler48's Avatar
Rewards Points: 850
Ouch, you'd better believe it. We installed 8" base throughout an entire house of PVC at the customers spec. Luckily it was a new house with a garage that we could cut in. It contained the PVC "dust" so sweeping wasn't too bad. I can only imagine if we had done it outside in the grass
Tom153 likes this.
Larry......
The Following User Says Thank You to chandler48 For This Useful Post:
Navane1 (12-05-2019)
