How To Connect PVC To Water Meter? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-17-2016, 11:11 PM   #31
Master Plumber
Javiles's Avatar
Rewards Points: 1,012
Re: How to connect PVC to water meter?
Don't cut the leader follow it to the end see what type of transition fitting is at the end work off that, as for bedding water line requires clean fill 4 inches all around that pipe from one end to the other, you may need to reground the home, by losing the metal and going plastic you lose the bonding on your electrical in the home.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
5/8 water meter with a 1 inch servise line ????? ogoz23 Plumbing 11 02-04-2012 10:35 PM
Water Meter Out of Control cdeliopo Plumbing 16 01-08-2012 10:08 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Frozen water meter stubborn1 Plumbing 5 01-26-2009 06:35 AM
