How To Connect PVC To Water Meter? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-15-2016, 06:24 PM   #1
Rewards Points: 28
How to connect PVC to water meter?
I need to replace the main water line from the meter at the street to the house. I'm not sure where to connect to the meter or with what type fittings. I will post some pics
bluegroove is offline   Reply With Quote
Old 03-15-2016, 06:32 PM   #2
Rewards Points: 582
Re: How to connect PVC to water meter?
ok will wait for pics...
Old 03-15-2016, 06:40 PM   #3
Rewards Points: 28
I'm gessing I can unscrew "a" and connect to that?
oops. picture truobles
Old 03-15-2016, 06:43 PM   #4
Rewards Points: 28
here we go
Old 03-15-2016, 06:44 PM   #5
Rewards Points: 28
heres the pipes and the top of the meter
How to connect PVC to water meter?-76.jpg   How to connect PVC to water meter?-70.jpg   How to connect PVC to water meter?-metertop.jpg   How to connect PVC to water meter?-metertop2.jpg
Old 03-15-2016, 06:46 PM   #6
Rewards Points: 28
so can I unscrew "a" ?
is "b" the input to the meter? It goes right up into the center of the meter. I'm assuming 'a' is output cuz it points towards the house
Old 03-15-2016, 09:15 PM   #7
Master Plumber
Javiles's Avatar
Rewards Points: 1,012
Need to find the leader pipe usually 3 to five5 feet long,from the meter its usually dense copper with an adapter at the end what your showing in the picture is an extension bridge to raise the meter.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
gregzoll (03-16-2016)
Old 03-15-2016, 11:46 PM   #8
Rewards Points: 28
So I have to dig a few feet more to find that I guess? Is the leader pipe laying horizontally?
Old 03-16-2016, 05:06 AM   #9
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,034
Ayuh,..... I'd recommend pex or hdp over pvc all day long,....
The Following User Says Thank You to Bondo For This Useful Post:
Old 03-16-2016, 07:40 AM   #10
SHEPLMBR's Avatar
Rewards Points: 178
hdp is way to go...no joints
SHEPLMBR is offline   Reply With Quote
Old 03-16-2016, 08:54 AM   #11
Master Plumber
Javiles's Avatar
recommend sch 80 pvc stronger than pex, not sure in your area but down here we have to sleeve pex in the ground with sch 40 pvc and correct bedding. not a fan of pex
Old 03-16-2016, 11:27 AM   #12
Rewards Points: 28
I've spoken with 4 diff local plumbers and they all recommend PVC. I guess that's the popular stuff here. I'm replacing old rusty galvanized pipe.
The Following User Says Thank You to bluegroove For This Useful Post:
Old 03-16-2016, 11:49 AM   #13
Rewards Points: 28
Hey Javiles what does "correct bedding " mean? thanks
Old 03-16-2016, 01:26 PM   #14
Rewards Points: 6,652
That is because they make more money from fixing broken PVC lines.
Keep in mind that since you are replacing metal with plastic, you loose that ground connection. The reason for the yoke. is so that you have a continuous ground to the main. Stick with good Copper, which comes in a roll and use it up to the shutoff in the house.
Old 03-16-2016, 01:35 PM   #15
SHEPLMBR's Avatar
Rewards Points: 178
They do know you are talking about your water main under ground and not a sprinkler line or in the house correct?
5/8 water meter with a 1 inch servise line ????? ogoz23 Plumbing 11 02-04-2012 10:35 PM
Water Meter Out of Control cdeliopo Plumbing 16 01-08-2012 10:08 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Frozen water meter stubborn1 Plumbing 5 01-26-2009 06:35 AM
