How To Connect Pex Tubing To Copper? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree4Likes
  • 1 Post By MTN REMODEL LLC
  • 1 Post By TheEplumber
  • 1 Post By rjniles
Old 11-22-2016, 08:37 PM   #1
Rewards Points: 191
How to connect Pex tubing to copper?
Need to replace my spigot, looking to use pex tubing and clamping system.
buddy gave me the tubing, tube cutter, and crimping tool already. i just need to get the connectors now. i am hoping to avoid sharkbites and dont have the tools to solder.
am i beat here or just go with the sharkbite and hope for the best?
rygar is offline   Reply With Quote
Old 11-22-2016, 10:56 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,754
Re: How to connect Pex tubing to copper?
I don't rcall exactly... but they may make a compression to pex conversion ... but for $ 6 bucks, I would go with sharkbite for both convvenence and less possibility of error.
supers05 likes this.
MTN REMODEL LLC is online now   Reply With Quote
Old 11-22-2016, 11:23 PM   #3
Rewards Points: 80
Sharkbite.
I thought HD sold the rings and fittings, I haven't checked for a while. My supplier does....
Cheers!
supers05 is offline   Reply With Quote
Old 11-22-2016, 11:25 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 174
Maybe your buddy has a torch so you could sweat on a pex adapter?
Old 11-23-2016, 12:15 AM   #5
Rewards Points: 191
i actually have a torch and spent 2 hours watching vids sweating copper.
pex adapater to copper is the way to go. i have about 4' of extra copper and i will buy some elbows tomorrow to practice. want to have a couple trial runs before i do the deed
Old 11-23-2016, 12:23 AM   #6
You'll do fine and surprize yourself how easy it is... especially considering you have studied it.
Protect combustables, use mapp gas (propane is not as hot and can be difficult for first time), clean it, dope it, heat it evenly all around thinking how heat travels up from the blue tip, and the solder will flow right into the joint as soon as it is hot enough,,,,
I would sweat it also (old timer) but I use sharkbites when convenient or difficult with a torch... I feel pretty confident in them now that they've been around awhile.
Good going
Old 11-23-2016, 05:12 AM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 806
Use flux on the solder joint not dope.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 11-23-2016, 08:57 AM   #8
RJ..... OOPS..... Thanks for catching .... I shouldn't use regional slang with someone just learning.
Ryger.... Hope my slang reference for flux did not confuse.
Old 11-23-2016, 10:58 AM   #9
Breakin' Stuff
Rewards Points: 1,374
You are on the right track. I learned to sweat a few days ago, only messed up the first one or two practice fittings and I am far from the skilled plumber. It's also really comforting to have that skill, especially if you own an older home.
Renovations to my 1947 home can be followed here: www.schlosserhouse.com
Bret86844 is offline   Reply With Quote
Old 11-23-2016, 01:05 PM   #10
Relate sort of a funny story... When I was pretty young, I was helping a neighbor friend with some manual labor around his remodel (clean up and go-for).... and he was starting to do some copper plumbing...
He was trying to figure out the order of his plumbing run/assembly to "be sure the solder would sweat and flow down into the joint". (Think about it... pretty darn or impossible assembly)
I did not know any better, and we tried to figure it out for quite a while and then quit.
The next weekend he had talked with a plumber, and explained to me (and showed me) how to sweat and that solder just sucks right up into the joint.
Best
Bret86844 likes this.
copper split ring pipe hangers Perry401 Plumbing 1 08-05-2015 11:36 PM
How should I prepare copper pipe for a quick connect fitting? amateurplumber Plumbing 7 07-22-2013 08:55 AM
connect aquarium tubing with a syringe navekool Plumbing 13 04-04-2013 08:32 AM
how to connect 1/4" copper to 3/4" for humidifier BlueBSH Plumbing 2 02-09-2012 01:35 PM
araist needs help with copper tubing lhering216 Plumbing 1 01-20-2011 10:45 AM
