How To Center Up Loose Faucet In Stone Counter Tops? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By MTN REMODEL LLC
  • 1 Post By jlhaslip
Old 10-24-2016, 06:50 PM   #1
Rewards Points: 58
How to center up loose faucet in stone counter tops?
The counter top installers bored the holes through our new soapstone counters. The faucet has two pipes that run down through it, at 1/2" each. The holes are like 1 1/2" in diameter, which I assume is standard size for a singe faucet. The trim on the faucet covers the hole, so no issue there. Any recommendations on a bushing to center up the pipes in the counter top? Right now they are loose and move around.
I thought about maybe some pvc pipe or a wood disc cut down to act as a bushing between the faucet and the counter top.
Thoughts ?
How to center up loose faucet in stone counter tops?-counter_1.jpg   How to center up loose faucet in stone counter tops?-counter_2.jpg
dman535 is offline   Reply With Quote
Old 10-24-2016, 07:09 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,764
Re: How to center up loose faucet in stone counter tops?
I would have thought that that faucet has a rubber O ring on top and a plastic or brass nut on its underside and just tighten it down...
I've never heard of having to use a bushing... it should just friction tight down...????
Fix'n it likes this.
MTN REMODEL LLC is online now   Reply With Quote
Old 10-24-2016, 07:54 PM   #3
Rewards Points: 58
There is a nut on the bottom of each pipe, I am sure I was being to easy on it for fear of cracking the counter tops. The instructions do specify a 1 1/2 hole, I just thought it would make sense to have something help center it. Guess I will just tighten up the nut and be done with it.
Old 10-24-2016, 08:17 PM   #4
jlhaslip's Avatar
Rewards Points: 708
"Snug" the nuts/fasteners and then check/double check their position before cinching them down tight.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 10-24-2016, 09:37 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 186
Add a small bead of clear silicone around the edge of the hole. Then tighten the under deck nuts as tight as possible while holding the faucet in position. After it cures it will act as a gasket and adhesive.
The Following User Says Thank You to TheEplumber For This Useful Post:
dman535 (10-27-2016)
Laminate counter tops, can they be joined? Strife_Design Kitchen & Bath Remodeling 6 07-05-2013 11:12 AM
Loose faucet handle [with photos] handeman Plumbing 7 07-13-2011 09:28 PM
Corian or Granite counter tops Jms92 General DIY Discussions 21 04-17-2010 06:18 PM
Lever faucet loose; poor flow Toe Plumbing 2 10-12-2009 02:44 PM
Loose / Bent Faucet yasman Plumbing 1 03-30-2009 08:50 PM
