How Can I Connect A Stand Pipe To My Existing Lines? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-11-2016, 07:05 PM   #1
Rewards Points: 322
How can I connect a stand pipe to my existing lines?
I'm currently renovating my laundry room. Previously the washing machine emptied into a laundry tub. I would like to install a standpipe for it to drain into instead.
I've attached a picture of the plumbing I currently have. In the picture you will see the old drain for the laundry tub, a line that connects to the left which comes from the kitchen sink upstairs, and a line in the back which is a vent. Would it be correct to connect the standpipe via a Y onto the horizontal part of the drain line that runs to the laundry tub? The only other option I can think of is connecting it onto the vertical part of the drain line that comes from the kitchen sink, however doing this would result in the trap being over 18 inches from the floor which from my understanding is not allowed.
Thanks for the help!
Lemkie is offline   Reply With Quote
Old 11-12-2016, 09:58 AM   #2
Rewards Points: 322
Re: How can I connect a stand pipe to my existing lines?
Does anyone have any suggestions at all? I'm at a stand still on this project until I can get this figured out...
Old 11-12-2016, 06:02 PM   #3
Rewards Points: 1,868
If your in a state that uses IPC code you can't your pipe is to small it would need 3 inch.
Are these power lines a concern being next to a tree? miamicuse Electrical 19 02-07-2016 04:46 PM
Install new faucet with compression fittings to larger copper supply lines cwb124 Plumbing 7 02-27-2013 04:11 PM
Tapping off of an existing duplex outlet OntarioDYI Electrical 2 09-02-2012 10:54 AM
connect new plumbing to existing bathroom plumbing flywithrhonda Plumbing 6 05-11-2012 07:27 PM
Combine 7' garage doors into one 16+ ft door - connect brick lintels Irestone Concrete, Stone & Masonry 12 03-22-2012 03:51 PM
