How Bad Is This Water Supply Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-30-2016, 04:04 PM   #1
Rewards Points: 258
How bad is this water supply pipe?
Hi all,
I've been working on repairs in my house and found a possible issue with the water supply pipe which carries water from the main to the water meter.
I have a link here to show you what we're dealing with:
http://s772.photobucket.com/user/mbr...r.jpg.html?o=0
How bad is this? Should it be replaced or is there a way to save it? I am working diligently on repairing the leak that is causing this. (It's a leak from rainwater entering the house)
Thanks for any and all help!
mbrando1994 is offline   Reply With Quote
Old 01-30-2016, 04:53 PM   #2
Rewards Points: 18,760
Just looks like way to much humity under the house which is causing condinsation and should never has been allowed to come in direct contact with the concrete.
Old 01-30-2016, 05:01 PM   #3
Rewards Points: 258
I know it's a direct water leak coming from the outside. It's been leaking that way for a while. It's seeping though the foundation wall. What are my options with this? Does it need to be replaced?
Old 01-30-2016, 05:09 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 31,580
It looks like a copper pipe. Other possibly being a bit small I no issues.
Old 01-30-2016, 05:13 PM   #5
Still waiting for those pictures outside.
Old 01-30-2016, 05:19 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 162
Originally Posted by mbrando1994 View Post
Hi all,
The only way to save it is to locate the leaks and make repairs at that location- if it is leaking. Clocking your meter will tell you that.
To replace it- you can dig in a new line or possibly have a new one pulled in- which saves a lot of trenching.
Old 01-30-2016, 05:21 PM   #7
And use Pex not copper.
Old 01-30-2016, 05:22 PM   #8
Rewards Points: 258
This is in Schuylkill County, Pennsylvania by the way, sorry I didn't include that earlier.
The leak is not pertaining to the pipe itself it is a leak of rainwater outside to in. What do you mean by pulling a new pipe in? I'm assuming I would need to replace out to the shut off at the main?
Old 01-30-2016, 05:29 PM   #9
Rewards Points: 258
I have fixed the links so they will work properly now
Old 01-30-2016, 05:33 PM   #10
Plumber
Rewards Points: 162
This is one method using a mole-
Another way is to hook a new line to the old one- then pull the old one out using hydraulics. The new line takes it's place and you make the connectons at each end
Old 01-30-2016, 05:35 PM   #11
Rewards Points: 258
I'm guessing the sidewalk will need to be dug up for this? The corporate stop is located under the pavement
Old 01-30-2016, 06:44 PM   #12
Rewards Points: 582
i have seen way worse pipes than that here in pa. that green is comming from the water leaking in from foundation reacting with the concrete and stone turning the pipe green..pipe itself looks pretty good ..if cost is not a factor and you want to replace it ...go ahead...if it is... sleeve it to protect it ...should get alot more life from it... imo.....
Old 01-30-2016, 08:21 PM   #13
Rewards Points: 1,848
It is probably K copper the thickest I doubt you will have an issue.
The Following User Says Thank You to Ghostmaker For This Useful Post:
ben's plumbing (01-31-2016)
Tags
leak , meter , supply pipe , water
Water Pipe Calcs - Interesting Result ddawg16 Plumbing 0 05-30-2012 11:19 AM
Need help fast please re hydronic boiler water supply and backflow DanDaMan Plumbing 21 12-22-2010 07:01 PM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 02:26 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 09:26 PM
