Hotwater Tank Water Leak And No Hot Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-13-2015, 01:47 PM   #1
Rewards Points: 18
Hotwater tank water leak and no hot water
Hi, please help with my hot water tank issue.
This water tank is bradford white gad water tank, has been in the house since day one I believe, so it is about 13 years old. (Maybe it's time to replace it).
This morning when I try to have a shower realize suddenly that hot water is gone. I went to basement and see water spilled out from bottom of the water tank, the hotwater fan is still running, but there is only cold water from anywhere of my house.
I checked the T&P valve it is dry, if I manually release the valve there is water coming out.
Drain valve is dry, there is no water.
On the top, peeping though the insulation around the connector of cold and hot water pipe, I can see the both are soaking wet, only the hot water pipe side is wet more.
Open the electric cover, everything is very dry.
Open the bottom cover, the bottom rim of the hot water tank is pretty rusty, seems there has been water there before.
I already shut of the switch and water of the water tank.
I included a lot of pictures, you can see the full album here: http://imgur.com/a/he1BN
Please guide me what I need check next? thanks
bayin is offline   Reply With Quote
Old 09-13-2015, 02:08 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,940
Sounds like the water heater has rusted out and sprung a leak.
Time for a new one.
The Following 4 Users Say Thank You to joed For This Useful Post:
bayin (09-13-2015), jmon (09-13-2015), Ron6519 (09-13-2015), SHR Plumber (09-17-2015)
Old 09-13-2015, 02:44 PM   #3
Rewards Points: 18
I just went down to basement and turned the cold water on, there are water immediately spring out from base of the hot water outlet, is it a common spot for failure? shall I try replace the dip tube first? or just go directly replace the whole hot water tank?
Old 09-13-2015, 02:47 PM   #4
Rewards Points: 127
The water tanks has sprung a leak. It's kaput. Time for a new one . Thirteen years is about as long a gas water will last
jimn01 is offline   Reply With Quote
The Following User Says Thank You to jimn01 For This Useful Post:
bayin (09-13-2015)
Old 09-13-2015, 02:54 PM   #5
Rewards Points: 18
Alright, i am heading HomeDepot now, lol. Thanks guys.
Old 09-13-2015, 06:15 PM   #6
Retired Moderator
Rewards Points: 7,174
May I suggest you get another Bradford White?
I have had trouble getting repair parts for any brand sold in the big box stores--only parts are available through the mail----who wants to wait for a shower until the post man arrives?
jmon (09-13-2015)
Old 09-15-2015, 10:07 PM   #7
Rewards Points: 18
Power vent or Direct vent?
Here am I again, I still haven't decide which to go, power vent or direct vent? My old gas hot water tank has power vent, do I have to replace it with a power vent water heater?
Thanks!
PS: I know I stink.
Old 09-16-2015, 12:42 AM   #8
Rewards Points: 970
I'll 2nd the recommendation on the Bradford White. I've also found they aren't any more expensive than going to the box stores, in fact I think I've paid less.
Master Brian is offline   Reply With Quote
The Following User Says Thank You to Master Brian For This Useful Post:
oh'mike (09-16-2015)
Old 09-16-2015, 04:50 AM   #9
Retired Moderator
Yes, if your system is designed for a power vent--then that is what you need.
Old 09-16-2015, 02:51 PM   #10
Rewards Points: 1,932
Power vent requires a power vent replacement.
Old 09-16-2015, 05:39 PM   #11
Rewards Points: 582
Bradford white ...power vent.... get errr done...
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (09-17-2015)
Old 09-17-2015, 10:59 AM   #12
Rewards Points: 38
Oh boy, the old which brand of water heater to purchase discussion. I love when customers have Bradford White water heaters. I am in the middle of replacing hundreds of leaking 6 year old Bradford Whites in a local development. I always replace with Rheem. But, kids in college so everyone else keep recommending and installing Bradford White. I love the premature replacement work!
SHR Plumber is offline   Reply With Quote
Old 09-17-2015, 04:09 PM   #13
They all are the same junk now. Lifetime of the average tank is 6 years. That way more can be sold. Sort of like all new appliances they all have built in failures.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Tags
hotwater tank , leak
Water leak causing increased Electrical Current? polling Electrical 11 09-30-2014 12:34 PM
Mini-project: Rebuilt my toilet. First time doing it. r0ckstarr Project Showcase 6 05-13-2014 02:59 PM
water leak seeping from floor HelenM Plumbing 9 03-02-2014 06:26 PM
well pressure tank leak wengang1 Plumbing 16 10-07-2010 08:59 AM
shower leak..hot water tank leak...HELP!!! Drie Plumbing 6 06-30-2010 02:12 PM
