Hot Water In Toilets - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-07-2016, 07:46 AM   #1
Rewards Points: 26
Hot water in toilets
Guys,
I have a 10 floor building with a pump on the first floor, electric water heaters on each floor. It seems like every morning the cold water lines get very hot for a few hours. Please help
mozart6099 is offline   Reply With Quote
Old 07-07-2016, 07:54 AM   #2
Rewards Points: 26
Re: Hot water in toilets
FYI: pump is off over night
Old 07-07-2016, 11:16 AM   #3
Rewards Points: 3,220
Does This happen on every floor.
Any recent plumbing work done?
jmon is offline   Reply With Quote
Old 07-07-2016, 12:17 PM   #4
Oso954's Avatar
Rewards Points: 1,614
I think the only thing you can do is to try leaving the pump on all night. See if that changes the situation.
If it doesn't, I would suggest you call a plumber to run it down. Hot water cross connections can be difficult to find in a normal home. It's a lot more difficult in a 10 story building.
Oso954 is offline   Reply With Quote
Old 07-07-2016, 12:22 PM   #5
Rewards Points: 26
Yes...a few projects have been done throughout
Old 07-07-2016, 01:07 PM   #6
Start there. Recheck all new plumbing work. Make sure of no cross connections. Try to narrow it down.
Try oso suggestion.
Old 07-09-2016, 07:55 AM   #7
Rewards Points: 3,286
A common reason for crossover is turning off a shower or mixing faucet using a spout or sprayer cutoff while leaving the faucets or main lever in the on position.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
Old 07-09-2016, 08:27 AM   #8
Rewards Points: 1,288
Not a plumber but I've read that enough pressure in the hot line/tank can backup into the cold line. Maybe the tanks need a pressure tank (name?)?
carpdad is offline   Reply With Quote
How to seal water line on outside to prevent leak into basement goshenplumber General DIY Discussions 14 10-27-2013 01:56 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
