Hot Water Temp - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-21-2015, 10:58 AM   #1
Rewards Points: 562
Hot water temp
Is this normal?
My 2 yr old GE water heater is set at 125
Even after running awhile the hot water out of faucet is 115
I drain sediment once a year.
Startingover is offline   Reply With Quote
Old 02-21-2015, 11:55 AM   #2
Rewards Points: 3,486
Yes, I would say so. Thermostat may be a little off. 10 degrees off isn't bad. None of them are exact. Remember when using the hot water there is constant cold water entering the tank to be heated mixing with the hot water.
Others will be along with more advice.
jmon is offline   Reply With Quote
The Following 2 Users Say Thank You to jmon For This Useful Post:
Fix'n it (02-22-2015), Startingover (02-21-2015)
Old 02-21-2015, 04:44 PM   #3
Rewards Points: 562
Jmon, thanks. I didn't know that. I try to be conservative but the dishwasher doesn't do a good job on greasy dishes if I don't pre-wash. Maybe what it cost to turn the water heater up I'll save by not running hot water pre-washing!
I'm the only one in the house but the plumber still recommended a 40 gal tank.
The Following User Says Thank You to Startingover For This Useful Post:
jmon (02-21-2015)
Old 02-21-2015, 06:15 PM   #4
Rewards Points: 3,130
Dishwashers need water at 140F for good cleaning, a temperature you can't even set most water heaters to (130 seems to be the max anymore). Maybe that's why virtually all but the cheapest dishwashers today have their own heater.
The Following User Says Thank You to md2lgyk For This Useful Post:
Old 02-21-2015, 06:44 PM   #5
Rewards Points: 562
Md21gyk, I was curious so just reset my HWH. The dial goes up to 150, but could be designed better.
There are no numbers or marks between 125 and 150. I had to guess where I was setting it, so started at less than the middle between both numbers.
Theres a danger sign saying temps over 125 could cause death. I'd hate for my obituary to read; "she died from 126 degree water."
Old 02-21-2015, 06:51 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 286
Actually, water temp at point of delivery should be 120* (per my code)
Commercial kitchens use a booster heater or a separate dedicated heater and piping to reach 140* for dish washing
You'll find that the typical WH thermostats will not be accurate- plus or minus 10*
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
gregzoll (02-21-2015), Startingover (02-21-2015)
Old 02-21-2015, 08:51 PM   #7
Rewards Points: 1,950
Water at 100F or below Most water heaters are unlikely to scald an adult occupant;
Water at 120F 5 minutes 2nd & 3rd degree burns on adult skin
Water at 130F 30 seconds 2nd & 3rd degree burns on adult skin
Water at 140F 5 seconds 2nd & 3rd degree burns on adult skin
Water at 150F 1 1/2 seconds 2nd & 3rd degree burns on adult skin
Water at 160F 1/2 second 2nd & 3rd degree burns on adult skin
The Following User Says Thank You to Ghostmaker For This Useful Post:
Startingover (02-22-2015)
Old 02-21-2015, 09:16 PM   #8
Rewards Points: 6,652
I do not see any problem with that drop. Remember that as you are letting Hot water out of the Water Heater, cold water is coming in at the same time. Which means that there will be a drop in temp as you are cycling Hot with Cold water.
The output temp has to be within 110 to 120 deg's Fahrenheit. If kids or handicap in the home. The temp should be set lower or Anti-Scald mix valves used to keep a person from burning their selves when they turn on the hot water.
The Following User Says Thank You to gregzoll For This Useful Post:
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 08:48 PM
Toilet flush issue. Paradiselost Plumbing 7 06-19-2012 12:47 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
