Hot Water Supply From Laundry Room Sink To Garden Hose - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree4Likes
  • 1 Post By 123pugsy
  • 1 Post By joecaption
  • 1 Post By TheEplumber
  • 1 Post By hkstroud
Old 06-05-2017, 11:44 AM   #1
Rewards Points: 30
Hot water supply from Laundry room sink to garden hose
I am trying to hook up a hot water supply from the laundry room sink to an outdoor kids pool. i am thinking i can tap into the hot water supply to the laundry sink.
Any ideas?
I was thinking if I can get a valve that I can plug in between the hot water supply to the sink which has 2 outlets. One that goes to the sink and other one with a valve that i can connect to a garden hose. Does anyone know if such a valve exists?
i drew a picture of what i need. Any help is appreciated.
st_group is offline   Reply With Quote
Old 06-05-2017, 12:00 PM   #2
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,706
Re: Hot water supply from Laundry room sink to garden hose
Google is your friend.
If you install a Tee, you can install two individual valves.
MTN REMODEL LLC likes this.
123pugsy is offline   Reply With Quote
Old 06-05-2017, 12:11 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,854
There are plenty of stop valves that are what you are looking for....but they are a 3/8 output...... and I suspect you want a 1/2 feed.... so as Pugsy says.... just put in a 1/2 tee before your sink stop.
(Maybe on the internet you can find a T stop with 1/2 and 3/8 outputs. Doubt that the Big Boxers will carry)
MTN REMODEL LLC is offline   Reply With Quote
Old 06-05-2017, 02:12 PM   #4
Rewards Points: 30
Thanks for you input. I think I can find what i need online.
Old 06-05-2017, 02:24 PM   #5
Rewards Points: 18,974
Why not add a splitter to the hot supply line for the washing machine?
http://www.homedepot.com/p/Melnor-2-...9000/100178887
Old 06-05-2017, 03:01 PM   #6
Rewards Points: 30
This won't work for me since the supply line is not easly accessible to me to be able to turn on/off (it's in a tight space behind the washer/dryer).........but thanks for your suggestion
Old 06-05-2017, 10:34 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 254
FYI- Without installing a vacuum breaker, what you are attempting to do is not allowed per plumbing codes. It's known as a cross connection. This means contaminants can enter your water system as well as your public system.
Your existing hose bib should have a vacuum breaker already installed. That is where you should fill your pool from. Then use a pool heater to heat the pool water.
joecaption likes this.
The Following User Says Thank You to TheEplumber For This Useful Post:
st_group (06-10-2018)
Old 06-06-2017, 05:54 AM   #8
hkstroud's Avatar
Rewards Points: 6,694
http://www.homedepot.com/p/DANCO-55-...0512/204321953
This should fit your spout. You can then connect your hose to the spout. Whether you use hot, cold or warm water is up to you.
Hot water supply from Laundry room sink to garden hose-a171ef5f-f120-4730-a76d-0992d2da82fc_1000.jpg
jeffmattero76 likes this.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
The Following User Says Thank You to hkstroud For This Useful Post:
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
Hooking a water hose to a water heater ITSANSS Plumbing 5 05-12-2012 10:01 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 09:26 PM
