Hot Water Particles And Discoloration - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2016, 09:13 AM   #1
Rewards Points: 224
Hot Water Particles and Discoloration
If we fill the tub with the tub spout. The hot water has a yellow color and some small pieces of metal flakes. Now at all my sinks the hot water is not discolored but there are metal flakes in the aerators.
I believe when I had a plumber change the tub handles and spout the tub looked to have a galvanized metal instead of copper, maybe this is rusted causing the yellow?
I have oil heat with direct hot water coils in the boiler. Before I start replacing stuff I would like some input of what you think it would be.
We have been filling the baby's tub with sink water unsure what is going on with the tub.
ryanb4614 is offline   Reply With Quote
Old 01-31-2016, 09:20 AM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
have the hot water coil cleaned, ultra sound....since there are no aerators in the tub spout its letting the brown stuff come through..it will clog up the sinks in due time..
WhatRnsdownhill is offline   Reply With Quote
Old 02-01-2016, 09:12 PM   #3
Rewards Points: 224
but the tub water is the only water that is discolored. I called a few places plumbers said they dont clean them only replace.
Old 02-01-2016, 10:08 PM   #4
Rewards Points: 1,852
A simple question if you run the tub for a bit does the color clear up. If so it is the galvanized pipe in the tub spout. I would suggest you replace with all brass nipples.
grout msrq Remodeling 11 01-11-2016 07:10 PM
Small Yard, Tree Roots....? JayNYOne Landscaping & Lawn Care 6 11-13-2011 06:30 PM
